How to display case wide local actions as popup
We have a case wide local action which is visible on assignments. This local action is used to change a date in the case. As this has very minimum functionality end users expects it should open in a modal dialog or popup. By default Pega opens it by replacing the current assignment display.
Any alternative solutions to display local action as a modal dialog?
Aniket
How have you configured the local action to be a case-wide action?
When adding a local action, the "Target" = "Replace Current" by default. This causes the behaviour you are experiencing.
Simply change the local action configuration to use "Target" = "Modal Dialog" (see attached image). This will open the local action without replacing the current assignment.
If you are using a Navigation rule, you can add this configuration there.
Regards
Sarah
