Disabling or Removing case/flow wide local actions?
There is a requirement to disable the case wide/flow wide local action listed in "other actions" dropdown menu for a particular section(at one point in the flow).
Is there a way from which we can disable the local actions listed in "other actions menu" for a particular section. I know there is a way to disable local actions conditionally from case or flow. But is there a way to do the configuration at a section or assignment level in a flow?
