For a calendar of anticipated patch release dates, see the Pega Infinity patch calendar.
Some recently reported issues were not included in the Infinity 26.1 release due to timing constraints. Pega will be providing select hotfixes for reported issues on a rolling basis to support updating to the most recent version of Infinity 26.1.
| HFIX# | Title | Fixed In Version | Description |
HFIX-D2771 for 26.1.0 HFIX-D3336 for 26.1.1 |
SAML Login / Logout Fails | Users cannot log in via SAML SSO in Infinity 26; error message displayed; login attempts fail for all users using the affected SAML provider. https://support.pega.com/support-doc/saml-login-logout-fails-pega-infin… |
The following issues have been reported and have additional information available.
| Issue | Support article |
| pyRefreshData is not invoked when submitting a popup post pega update to 25.1.3 | https://support.pega.com/support-doc/pyrefreshdata-is-not-invoked-when-… |
Preview PDF documents in attachments fails in Edge browser |
https://support.pega.com/support-doc/preview-pdf-documents-in-attachmen… |
HTMLToPDF causes unexpected column resizing results |
https://support.pega.com/support-doc/htmltopdf-causes-unexpected-column… |
pyRelatedWork section fails to auto-refresh |
https://support.pega.com/support-doc/pyrelatedwork-section-fails-auto-r… |
Multi-select Fails to Render in Modal Window |
https://support.pega.com/support-doc/multi-select-fails-to-render-in-mo… |
Disconnected environment in PDC home page after upgrading to Infinity 26 or later versions |
https://support.pega.com/support-doc/disconnected-environment-pdc-home-… |
