HCL Technologies BV
Last activity: 5 Aug 2024 14:54 EDT
Issue while creating case via the action set of a button using case worker portal
We are facing an issue while creating cases via the action set of a button using case worker portal using Theme-Cosmos.
The functionality works when user navigates to developer portal and then navigates back to user portal but does not work when user lands directly in user portal and clicks on the button.
Under networks, it is observed system returns the following (for api - createNewWork): The server understood the request but refuses to authorize it.
Thank you!
