Pega Notification Manager Service does not start
Hello everybody!
I need to start Pega Notification Manager Service in order to run an automation that uses a Windows Application Adapter with StartandWait propery value. However, when I try to execute Pega.Robotics.Service.exe it appears the following error:"Unable to open private Shared Memory" (Screenshots are attached).
Do you know how I can solve this?
Thank you!
The service is designed to start on the startup of the machine. If it fails to start, it is can be a sign that something is blocking it from starting.
Traditionally, you can start the service from the Services.msc console and it should be okay as well.
It may also fail to start if you have installed the Pega Native Foundation anywhere other than the installation directory of Pega Robotics Studio/Plugin/Runtime.
