Pega Business Agility Framework and Pega Revision Management
I'm not able to find anything on Pega's website about the Business Agility Framework. Can someone provide context?
Is Pega Business Agility Framework a part of Pega Revision Management? If so, how do the two fit together?
How does the Business Agility Framework tie into Pega CDH?
@BrianaJ9 , You can think of Revision Management and Business agility in Customer Decision Hub (CDH) as one and the same thing. In the last few releases we re-imagined how all this agility can be brought to life in CDH and did so through a capability called 1:1 Operations Manager. The revision manager technology underpins the new capability, but through a new and modern Case based UI. To learn about the capability, I highly encourage you to look at the enablement material for it, located here: https://academy.pega.com/mission/business-agility-11-customer-engagement/v1
