Ford Motor Company
Posted: July 9, 2019
Last activity: July 10, 2019
Last activity: 10 Jul 2019 16:38 EDT
Getting an error while Upgrading from 7.1.9 to 7.4
Targets:Update
Unable to locate tools.jar.
Show More
Targets:Update
Unable to locate tools.jar. Expected to find it in C:\Program Files\Java\jre8\lib\tools.jar
Buildfile: C:\Users\*******\Desktop\115944_Pega74-U\.\pegaGuiInstallerTemp\build.xml
SetupProperties:
Update:
[echo] calling update ....
update:
startover_or_resume:
[pega:propertyparser] Reading Properties from: C:\Users\*******\Desktop\115944_Pega74-U\scripts/setupDatabase.properties
[echo] Performing update...
Initialization:
[echo] Performing Update Finalization
[echo] Using logging configuration from: ./config/deploylogging.properties
[mkdir] Created dir: C:\Users\*******\Desktop\115944_Pega74-U\scripts\taskRuntimes
pega.jdbc.driver.jar=C:\Users\****\Desktop\sqljdbc4.jar
pega.jdbc.driver.class=com.microsoft.sqlserver.jdbc.SQLServerDriver
pega.database.type=mssql
pega.jdbc.url=jdbc:sqlserver://*******:1433;databaseName=*****;SelectMethod=cursor;SendStringParametersAsUnicode=false
pega.jdbc.username=*******
pega.jdbc.password=*****
pega.admin.password=*****
rules.schema.name=Rules
data.schema.name=dbo
customerdata.schema.name=
user.temp.dir=
pega.zos.properties=
system.name=pega
production.level=2
multitenant.system=false
update.existing.applications=false
update.applications.schema=true
automatic.resume=true
pega.jdbc.driver.jar=C:\Users\*******\Desktop\sqljdbc4.jar
user.temp.dir=
system.name=pega
production.level=2
[pega:propertyparser] pega.jdbc.driver.class=com.microsoft.sqlserver.jdbc.SQLServerDriver
[pega:propertyparser] update.existing.applications=false
[pega:propertyparser] pega.jdbc.password=*****
[pega:propertyparser] update.applications.schema=true
[pega:propertyparser] automatic.resume=true
[pega:propertyparser] pega.jdbc.driver.jar=C:\Users\*******\Desktop\sqljdbc4.jar
[pega:propertyparser] rules.schema.name=Rules
[pega:propertyparser] pega.jdbc.url=jdbc:sqlserver://******:1433;databaseName=*****;SelectMethod=cursor;SendStringParametersAsUnicode=false
[pega:propertyparser] pega.database.type=mssql
[pega:propertyparser] user.temp.dir=
[pega:propertyparser] production.level=2
[pega:propertyparser] pega.zos.properties=
[pega:propertyparser] customerdata.schema.name=
[pega:propertyparser] pega.jdbc.username=******
[pega:propertyparser] pega.admin.password=*****
[pega:propertyparser] multitenant.system=false
[pega:propertyparser] system.name=pega
[pega:propertyparser] data.schema.name=dbo
[echo] *** JVM Arguments -XX:MaxHeapSize=1280m ***
[propertyfile] Creating new property file: C:\Users\*******\Desktop\115944_Pega74-U\scripts\resume.properties
[propertyfile] Updating property file: C:\Users\*******\Desktop\115944_Pega74-U\scripts\resume.properties
Found 99264240KB of free space on 'C:\Users\*******\AppData\Local\Temp\'
[echo] setting to generated ddl
[echo] Driver Path: C:\Users\*******\Desktop\sqljdbc4.jar
[mkdir] Created dir: C:\Users\*******\AppData\Local\Temp\PegaInstallTemp-09-July-2019-09.13.52\load
[mkdir] Created dir: C:\Users\*******\AppData\Local\Temp\PegaInstallTemp-09-July-2019-09.13.52\pr_temp
[touch] Creating C:\Users\*******\Desktop\115944_Pega74-U\scripts\logs\Warnings.log
[echo] Using C:\Users\*******\AppData\Local\Temp\/PegaInstallTemp-09-July-2019-09.13.52 for install scratch space...
[unzip] Expanding: C:\Users\*******\Desktop\115944_Pega74-U\archives\prweb.war into C:\Users\*******\AppData\Local\Temp\PegaInstallTemp-09-July-2019-09.13.52\load
[unzip] Expanding: C:\Users\*******\Desktop\115944_Pega74-U\archives\pegadbinstall-classes.zip into C:\Users\*******\AppData\Local\Temp\PegaInstallTemp-09-July-2019-09.13.52\load
[copy] Copying 1 file to C:\Users\*******\AppData\Local\Temp\PegaInstallTemp-09-July-2019-09.13.52\load\WEB-INF\classes
Checking Configuration Files:
[echo] Rules schema has been set to 'Rules'
[echo] ***writing resume property upgrade.from.version=07-10-20 to file***
[echo] Upgrading from Pega-RULES product version 07-10-20
Processing Configuration Files:
[propertyfile] Creating new property file: C:\Users\*******\AppData\Local\Temp\PegaInstallTemp-09-July-2019-09.13.52\prbootstrap.properties
Configuration:
[echo] Database Type: mssql
[echo] JDBC Driver JAR: C:\Users\*******\Desktop\sqljdbc4.jar
[echo] Bootstrap Config: C:\Users\*******\AppData\Local\Temp\/PegaInstallTemp-09-July-2019-09.13.52/prbootstrap.properties
[echo] PegaRULES Config: C:\Users\*******\AppData\Local\Temp\/PegaInstallTemp-09-July-2019-09.13.52/prconfig.xml
[echo] PegaRULES Logging Config: C:\Users\*******\AppData\Local\Temp\/PegaInstallTemp-09-July-2019-09.13.52/prlog4j2.xml
[echo] Deployment Logging Config: ./config/deploylogging.properties
Verify ML Readiness:
System meets basic requirements for update to 07-10-35
PRPC_Rules build date: 2018-04-11 12.36 UTC
No superseded code or rules.
Generate Upgrade DDL:
[mkdir] Created dir: C:\Users\*******\Desktop\115944_Pega74-U\schema\generated\mssql\upgrade
[mkdir] Created dir: C:\Users\*******\Desktop\115944_Pega74-U\schema\generated\mssql\util
Execute SQL In Transaction:false
_clean:
[echo] Cleaning up previous invocation...
[delete] Deleting directory C:\Users\*******\Desktop\115944_Pega74-U\schema\generated\mssql
[echo] Cleaning up previous invocation...(Complete)
_createOutputDirs:
[echo] Creating output directory at C:\Users\*******\Desktop\115944_Pega74-U\scripts/../schema/generated/mssql
_callDDLUtilityUpgrade:
[echo] Call DDL Generation Upgrade Utility...
[echo] C:\Users\*******\Desktop\115944_Pega74-U\scripts/lib/xercesImpl.jar;C:\Users\*******\Desktop\115944_Pega74-U\scripts/lib/xml-apis.jar;C:\Users\*******\Desktop\115944_Pega74-U\scripts/lib/resolver.jar;
[echo] archive_dir: C:\Users\*******\Desktop\115944_Pega74-U\scripts/lib
[java] 2019-07-09 09:14:41,245 ( install) INFO - Initializing properties with default values
[java] 2019-07-09 09:14:41,355 ( install) INFO - Setting default Entity Value for pega_enable_nologging = true
[java] 2019-07-09 09:14:41,355 ( install) INFO - Getting database metadata
[java] 2019-07-09 09:14:44,789 ( install) INFO - Reading views from schema "dbo"
[java] Exception in thread "main" java.lang.RuntimeException: Error during execution of upgrade on platform mssql using schemas Rules, dbo, dbo
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.main(SchemaGenerator.java:1569)
[java] Caused by: com.pega.pegarules.data.ddl.DatabaseException: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'pr4_rule_vw'.
[java] at com.pega.pegarules.data.ddl.SchemaManager.<init>(SchemaManager.java:439)
[java] at com.pega.pegarules.data.ddl.SchemaManager.<init>(SchemaManager.java:480)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.saveCurrentSchemaState(SchemaGenerator.java:496)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.main(SchemaGenerator.java:1395)
[java] Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'pr4_rule_vw'.
[java] at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:216)
[java] at com.microsoft.sqlserver.jdbc.TDSTokenHandler.onEOF(tdsparser.java:254)
[java] at com.microsoft.sqlserver.jdbc.TDSParser.parse(tdsparser.java:84)
[java] at com.microsoft.sqlserver.jdbc.SQLServerResultSet.<init>(SQLServerResultSet.java:311)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1526)
[java] at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:404)
[java] at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:350)
[java] at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:5696)
[java] at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1715)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:180)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:155)
[java] at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:285)
[java] at com.pega.pegarules.data.ddl.JDBCIntrospector.getTablesDependentonViews(JDBCIntrospector.java:1631)
[java] at com.pega.pegarules.data.ddl.JDBCIntrospector.readViews(JDBCIntrospector.java:496)
[java] at com.pega.pegarules.data.ddl.JDBCIntrospector.createDatabaseJaxbObjectByIntrospection(JDBCIntrospector.java:120)
[java] at com.pega.pegarules.data.ddl.SchemaManager.createDomDocumentFromDbIntrospection(SchemaManager.java:2039)
[java] at com.pega.pegarules.data.ddl.SchemaManager.<init>(SchemaManager.java:435)
[java] ... 3 more
Show Less
