Upgrade - migrate bat file failed to run - Pega 7.1.9
Steps:
- Downloaded pega 719 package
- unzipped the file
- Updated migratesystem.properties as advise in upgrade document
- from command prompat went to the local direcotry where script folder is in unzipped filed from above
- Run the migrate.bat
Error:
The JAVA_HOME environment variable must be defined.
The system cannot find the batch label specified - Error
Can someone advise if this can be run from local machine? and if yes what action I should take to resolve the issue encountered.
@AmitK283
This issue occurs if Java is not installed or JAVA_HOME environment variable is not defined in the machine from where you are running the upgrade.
Kindly refer the system requirement section in upgrade guide.
https://docs-previous.pega.com/pega-719-platform-upgrade-guide?
719 is very old version of Pega. any specific reason to upgrade to such an old release/
I would suggest that you should look to upgrade to latest 8.x version .
8.7.x is latest Pega release. Here are the details of whats new feature with platform.
https://community.pega.com/products/whats-new/platform
