Getting BUILD Failed error while updating to 7.1.9 from 7.1.7
Getting build failed error while updating from 7.1.9 from 7.1.7. It says that a couple of rules were updated after the release was built. One of which we got through a hotfix on 7.1.7.
The error message is :
Verify ML Readiness:
System meets basic requirements for update to 07-10-19
PRPC_Rules build date: 2015-08-26 18.28 EDT
The following rules were updated after this release was built:
pzinskey pxUpdateDateTime
RULE-APPLICATION PEGARULES 06.02.25 2015-09-22 06:30:57
RULE-OBJ-ACTIVITY RULE-HTML-HARNESS UPGRADEONOPEN #20150914T180234.771 GMT 2015-09-18 10:58:16
These instances may not be found by rule resolution after updating.
Please contact Pega Support to evaluate whether to continue the update process.
BUILD FAILED
/apps/SKYC/Pega719/scripts/setupDatabase.xml:381: The following error occurred while executing this line:
/apps/SKYC/Pega719/scripts/setupDatabase.xml:1492: This update cannot be applied, the system contains hotfixes generated after this release was built.
