Confirm Harness is shown when first assignment in a flow is routed to workbasket
I have flow for which the first assignment is routed to workbasket. I have enabled "Also consider an assignment in a workbasket" in the Process tab of the flow. Apart from that also tried to enable back to back assignment "For each also consider assignments in workbaskets". But still confirm harness was coming after creating the work object.
P.S. - Operator work group is also same as mentioned in the Workbasket.
Any suggestions will help.
