Bank of Singapore
SG
Last activity: 4 Jan 2021 9:27 EST
How to Skip Confirm harness when routed to workbasket and display in perform
Hi All
We have two assignments in the same flow, both of them are routed to same workbasket.
After finishing the first assignment confirm harness is displaying on routing to the second assignment
Our requiremnt is user should be able to toggle between the two assignments.
Tried below approaches
- checked 'Also consider an assignment in a workbasket' in my pyStartCase flow
- enabled "Also consider an assignment in a workbasket" in the Process tab of the flow.
- enabled back to back assignment "For each also consider assignments in workbaskets".
- Updated the operator with the workbasket
But still confirm harness was coming after routing the work object.
Any suggestions will help.
Thanks in advance!!!
You can try to change first assignment's flow action post behavior. You can have a look at back to back processing config on the action tab of flow action.
