TCS
Last activity: 1 Apr 2025 4:45 EDT
In Recording robotic automations Challenge, Adapter Exception for BankerInsight App
When I try to record the BankerInsight Application through Pega Robotics Studio, I keep getting the Adapter exception:
An unhandled exception occurred within BankerInsight. Would you like to shut down the adapter.
Exception Message:
Object reference not set to an instance of an object.
In the window, if I select yes, I get Unable to interrogate control. It may have been destroyed. One or more steps may not be recorded.
I have attached the screenshots for reference. Please help me get this issue resolved.
Thank you,
Gouri
Reply
Updated: 27 Mar 2025 10:23 EDT
Gouri, I see you already updated your PRS version as you had a previous post, so I am assuming that you updated and are receiving a new error. I will loop in support because it may be a bigger issue than the challenge. Thanks for your patience.
Michael Lambert
Gouri, when you updated your install, was Chrome or Edge still open during the installation process for Pega Robot Studio? Can you check in the browser if your Pega Extension is enabled? If not, please do so. and then restart Pega Robot Studio to try to the challenge.
Michael Lambert
TCS
Thank you for your response.
I actually removed my previous robotics projects, then uninstalled the previous not working Robotic Studio and PNF versions through programs and features. Then I reinstalled the newly downloaded version from the challenge when I got the newer version.
I did not have any browsers open during browser extension installation. I also enabled the extension in both chrome and edge. I also set each for default browser to see if I things are working in for the web application to make sure its not that specific browser issue.
For the web application recording I do not see errors but I don't see the gear icon on hover for the controls either.
For the Windows application I get the shared error.
-Gouri
Thanks Gouri. That info helps to better understand what is going on. I was not successful in the recreating your issue on my machine.
I have sent an email to support to assist. I will include this information to them as well, as it helps pinpoint where we may have solution.
I apologize that you are having this issue.
Michael
I created a support ticket with our Global Customer Support group. I am not sure if they are able to reach out to you. Can you provide your TCS email address so that I may add it to the ticket so may contact for any necessary information required during their triaging? Thanks.
Michael
TCS
Can you please provide me with a secure method to share my work email address?
-Gouri
@GOURIKW please either use the Academy Contact Us form that you can find via the Get Help pages (where you can find Contact Us forms which allow you to select the department you need to contact in the dropdown), or find Michael on LinkedIn.
@Michael Lambert we cannot permit users to post PII details on this public forum. Please see the Support Center Guidelines page
TCS
Gouri,
As of today, our support members are not able to reproduce your specific error. Do you know if you are running and security software application on your computer? If so, that may be the problem. Because the technology that PRS uses injects into the application code, sometimes settings on security software block that access Robot Studio needs to interrogate.
Can you check with your organization if that is the case? You may need to work with your IT to allow that with your security software. A similar documentation article is found here that may help explain what may be required by your IT department.
Michael
TCS
I am following the course on my personal laptop, and I have disabled both Windows Defender and the Ant-ivirus software. Also I tried adding them to the anti-virus exclusion list.
I still get the same error after that.
I am thinking of removing the Pega RPA software I downloaded from the challenge(those are the only Pega RPA software I have) and reinstalling the file. Can you please give me the link to any guide or can you please give me the exact steps I should follow to achieve this? May be I didn't get the previous non-compatible version from the exercise completely removed when I uninstalled it. (I had an issue with the PNF version not being compatible with my OS version.)
Thank you
Gouri
