Synechron Technologies
Last activity: 8 Dec 2022 2:04 EST
Utility shape
Hi ,
I'am using PEGA version 8.4 and while creating a new case type i need to include utility as a step in my process , but cannot find utility shape in process modeler also. Can someone help me in this regard. Thanks. Ashish Gupta
Updated: 12 Jun 2020 5:40 EDT
Evonsys
If you are opening the case type from App Studio click on "Open Process in Dev Studio" link. If you are opening case type from Dev studio click on "Open Process".
Now you can see Utility shape in the list.
IQZ Systems
Hi
You can add it in the flow rule corresponding to that process. You can not add it directly in the case type editor. 😃
Updated: 14 Jun 2021 7:38 EDT
Lloyds Technology Centre
When you try to add new shape in the Flow rule, is utility shape not there in the list?
While trying to add utility shape from process modeler i cannot find option for utility shape under add shape.
Please find the screenshot attached.
Thanks.
IQZ Systems
Hi
You should open the flow to add the utility shape. It will not be present in Process Modeler. Click on Open Process available at top right corner. Then you can add the Utility in the flow rule 😀
Ashish Gupta Pooja Palla
Thankyou for the help . I explored it and found it later
Sri Technology Services Inc.
@Ashish Gupta
Got the same issue as yours. Unable to find the utility shape in workflow
Evonsys
Ashish Gupta Trupti Thakre
DXC Technology
you can get it here.
@Shyju Thanks it works But Can you find the reason why when we click the utility option is not seen in some section?
