Staidlogic
Staidlogic
Staidlogic
Posted: Jul 9, 2018
Last activity: Jul 26, 2018
Last activity: 26 Jul 2018 16:34 EDT
Developer portal is refreshing upon navigation from opened portal
After launching portal from designer studio, if we try to navigate back to designer studio entire application is refreshing and closing the opened portal. Articles Referred: https://community.pega.com/support/support-articles/secondary-portal-closes-switch-back-designer-studio https://community.pega.com/support/support-articles/secondary-portal-closes-switch-back-designer-studio Still the issue is happening after following the steps in the two articles. Below exception is triggering web.impl.WebStandardImpl) WARN - I/O Exception occurred while writing or flushing the stream org.apache.catalina.connector.ClientAbortException: java.io.IOException: Broken pipe at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:356) at org.apache.catalina.connector.OutputBuffer.flushByteBuffer(OutputBuffer.java:815) at org.apache.catalina.connector.OutputBuffer.doFlush(OutputBuffer.java:310) at org.apache.catalina.connector.OutputBuffer.flush(OutputBuffer.java:284) at org.apache.catalina.connector.CoyoteOutputStream.flush(CoyoteOutputStream.java:118) at com.pega.jcraft.jzlib.DeflaterOutputStream.flush(DeflaterOutputStream.java:159) at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:297) at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141) at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229) at com.pega.pegarules.web.impl.DirectStreamWriter.flush(DirectStreamWriter.java:190) at com.pega.pegarules.web.impl.DirectStreamWriter.flush(DirectStreamWriter.java:183)
Show More
After launching portal from designer studio, if we try to navigate back to designer studio entire application is refreshing and closing the opened portal. Articles Referred: https://community.pega.com/support/support-articles/secondary-portal-closes-switch-back-designer-studio https://community.pega.com/support/support-articles/secondary-portal-closes-switch-back-designer-studio Still the issue is happening after following the steps in the two articles. Below exception is triggering web.impl.WebStandardImpl) WARN - I/O Exception occurred while writing or flushing the stream org.apache.catalina.connector.ClientAbortException: java.io.IOException: Broken pipe at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:356) at org.apache.catalina.connector.OutputBuffer.flushByteBuffer(OutputBuffer.java:815) at org.apache.catalina.connector.OutputBuffer.doFlush(OutputBuffer.java:310) at org.apache.catalina.connector.OutputBuffer.flush(OutputBuffer.java:284) at org.apache.catalina.connector.CoyoteOutputStream.flush(CoyoteOutputStream.java:118) at com.pega.jcraft.jzlib.DeflaterOutputStream.flush(DeflaterOutputStream.java:159) at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:297) at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141) at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229) at com.pega.pegarules.web.impl.DirectStreamWriter.flush(DirectStreamWriter.java:190) at com.pega.pegarules.web.impl.DirectStreamWriter.flush(DirectStreamWriter.java:183) at com.pega.pegarules.web.impl.WebStandardImpl.sendOutput(WebStandardImpl.java:881) at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:409) at sun.reflect.GeneratedMethodAccessor72.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370) at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411) at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224) at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273) at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121) at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:92) at javax.servlet.http.HttpServlet.service(HttpServlet.java:635) at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:80) at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:624) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342) at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:799) at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1455) at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745) Caused by: java.io.IOException: Broken pipe at sun.nio.ch.FileDispatcherImpl.write0(Native Method) at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) at sun.nio.ch.IOUtil.write(IOUtil.java:65) at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471) at org.apache.tomcat.util.net.SecureNioChannel.flush(SecureNioChannel.java:143) at org.apache.tomcat.util.net.SecureNioChannel.write(SecureNioChannel.java:631) at org.apache.tomcat.util.net.NioBlockingSelector.write(NioBlockingSelector.java:101) at org.apache.tomcat.util.net.NioSelectorPool.write(NioSelectorPool.java:157) at org.apache.tomcat.util.net.NioEndpoint$NioSocketWrapper.doWrite(NioEndpoint.java:1259) at org.apache.tomcat.util.net.SocketWrapperBase.doWrite(SocketWrapperBase.java:670) at org.apache.tomcat.util.net.SocketWrapperBase.writeBlocking(SocketWrapperBase.java:450) at org.apache.tomcat.util.net.SocketWrapperBase.write(SocketWrapperBase.java:388) at org.apache.coyote.http11.Http11OutputBuffer$SocketOutputBuffer.doWrite(Http11OutputBuffer.java:644) at org.apache.coyote.http11.filters.ChunkedOutputFilter.doWrite(ChunkedOutputFilter.java:121) at org.apache.coyote.http11.Http11OutputBuffer.doWrite(Http11OutputBuffer.java:235) at org.apache.coyote.Response.doWrite(Response.java:541) at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:351)
Show Less
