Accenture
Last activity: 30 Jun 2017 6:11 EDT
PegaCHAT onpremise installation - NVM version
I could not find NVM v2.7.x as recommended in installation instruction document. I can only find v0.33.2. Can you please provide the URL for NVM v2.7.x download?
Hello!
I read in an internal discussion that the NVM is bundled along with the Node.js. Which version of Node.js do you have?
Accenture
Hi Lochana,
I am planning to use NVM for installation of node.js v0.10.36 using command: nvm install 0.10.36
In PegaCHAT & Co-Browse onpremise installation document system requirement, NVM version to be used is mentioned as v2.7.x and v3.8.9 respectively. But I am not able to find these version in any site. I could only find NVM v0.33.2 from GitHub.
Can you provide URL to download NVM v2.7.x and v3.8.9?
EPAM Systems
CH
Are you trying to install PegaCHat 7.1.4?
Install nvm following instructions from https://github.com/creationix/nvm
Install node v0.10.36 using nvm. Simply execute nvm install 0.10.36
Update the npm that was installed with node. Execute npm install -g [email protected]
Accenture
Hi Bruet,
NVM v0.33.2 is available in GitHub. As per directions in the PegaCHAT and Co-Browse onpremise installation document, NVM version to be installed is v2.7.x and v3.8.9 respectively. I am not able to find these versions online. Can you please provide the URL to download these versions?
If the purpose of NVM is only to install and manage node.js (in PegaCHAT & Co-Browse), please let me know if nvm v0.33.2 can also be used, since node.js v0.10.36 and v4.4.3 is available in nvm v0.33.2
Product version:
Pega Co-Browse: v7.22.1
PegaCHAT: v7.22
EPAM Systems
CH
Thank you for your comment. There seems to be a something wrong with the document. It should state NPM (Node Package Manager) v2.7.x.
"If the purpose of NVM is only to install and manage node.js (in PegaCHAT & Co-Browse), please let me know if nvm v0.33.2 can also be used since node.js v0.10.36 and v4.4.3 is available in nvm v0.33.2"
Yes, whatever is available from GitHub can be used. I will pass this on to correct the documentation.
Accenture
Hi team,
The pre-requisite software versions specified in PegaCHAT onpremise installation document is incorrect.
Below are the correct versions
• Linux-Based Operating System based on kernel version 3.16.0-31-generic
• Node v4.4.3
• NPM v3.8.9
• MongoDB v3.2.9
• Redis v3.2.4
Please update the document.
Updated: 30 Jun 2017 6:11 EDT
Hello!
This has been reported previously over this post: PegaCHAT application server startup - Issue with execution of connect-mongo/src/index.js
The document has been updated: https://docs-previous.pega.com/premises-chat-server-installation-0
Thank you for your patience,
