Error in Logs while any Interaction from WL or WB
On Opening any service intent from worklist or work basket , we see below message in logs:
Required parameter'InteractionId' for data page 'D_Interaction' cannot be blank
Please explain how to attend this defect.
While I haven't seen that particular error before, a good place to start might be to trace an attempt to open an item that throws the error. The trace might be able to tell you where the error is coming from. If you have scenarios where opening an item doesn't throw that error, you could potentially trace one of those as well, to see where the missing parameter usually gets set.
Hope this helps!
-Kurt
