Jk Technosoft
Last activity: 31 Mar 2017 12:03 EDT
Error While logging in
Hi Guys,
I installed Pega v7.2.2 in my laptop and worked nicely for one day. I am getting the error while opening the tool after restarting the system.Its got stuck here for long time. Please Advise.
Thanks in Advance,
Bharath
Jk Technosoft
Thank You Guys. I got this problem Solved. But I don't know how. If it doesn't work also i am able to manage to make it work. If I have an issues regarding this. I'll be back.
OCBC Bank
SG
Hi Bharath,
The screenshot only shows that prweb.war has been successfully deployed but on top of that, there seems to be some error stack trace which is not visible properly.
It would be better if you can share the stack trace completely.
Jk Technosoft
server starting
Using CATALINA_BASE: "C:\PRPCPersonalEdition\scripts\..\tomcat"
Using CATALINA_HOME: "C:\PRPCPersonalEdition\scripts\..\tomcat"
Using CATALINA_TMPDIR: "C:\PRPCPersonalEdition\scripts\..\tomcat\temp"
Using JRE_HOME: "C:\PRPCPersonalEdition\jre1.8.0_111"
Using CLASSPATH: "C:\PRPCPersonalEdition\scripts\..\tomcat\bin\bootstrap.jar;C:\PRPCPersonalEdition\scripts\..\tomcat\bin\tomcat-juli.jar"
06-Mar-2017 10:52:37.971 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.5.8
06-Mar-2017 10:52:37.974 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Nov 3 2016 21:14:13 UTC
06-Mar-2017 10:52:37.975 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: Proprietary information hidden
06-Mar-2017 10:52:37.975 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 10
06-Mar-2017 10:52:37.975 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
server starting
06-Mar-2017 10:52:37.975 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
06-Mar-2017 10:52:37.975 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\PRPCPersonalEdition\jre1.8.0_111
06-Mar-2017 10:52:37.975 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_111-b14
06-Mar-2017 10:52:37.975 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
06-Mar-2017 10:52:37.975 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\PRPCPersonalEdition\tomcat
06-Mar-2017 10:52:37.976 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\PRPCPersonalEdition\tomcat
06-Mar-2017 10:52:37.976 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms2048m
06-Mar-2017 10:52:37.976 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
06-Mar-2017 10:52:37.976 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\PRPCPersonalEdition\scripts\..\tomcat\conf\logging.properties
06-Mar-2017 10:52:37.977 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
06-Mar-2017 10:52:37.977 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -DPETomcatHTTPPort=8080
06-Mar-2017 10:52:37.979 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=
06-Mar-2017 10:52:37.979 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\PRPCPersonalEdition\scripts\..\tomcat
06-Mar-2017 10:52:37.980 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\PRPCPersonalEdition\scripts\..\tomcat
06-Mar-2017 10:52:37.980 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\PRPCPersonalEdition\scripts\..\tomcat\temp
06-Mar-2017 10:52:37.981 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\PRPCPersonalEdition\jre1.8.0_111\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\PRPCPersonalEdition\jre1.8.0_111\bin;C:\PRPCPersonalEdition\jre1.8.0_111\bin\server;"C:\PRPCPersonalEdition\scripts\..\pgsql\bin";C:\Program Files (x86)\Lenovo\FusionEngine;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Skype\Phone\;C:\Users\user3\AppData\Local\Microsoft\WindowsApps;;.
06-Mar-2017 10:52:38.128 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
06-Mar-2017 10:52:38.253 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
06-Mar-2017 10:52:38.256 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-9009"]
06-Mar-2017 10:52:38.258 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
06-Mar-2017 10:52:38.258 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 717 ms
06-Mar-2017 10:52:38.290 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
06-Mar-2017 10:52:38.291 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.8
06-Mar-2017 10:52:38.320 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\PRPCPersonalEdition\tomcat\webapps\prweb.war
06-Mar-2017 10:52:38.969 INFO [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PRFileStore Ignoring unknown property: value of "Database-based File Access" for "description" property
06-Mar-2017 10:52:38.979 INFO [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = AdminPegaRULES Ignoring unknown property: value of "PegaRULES Admin datasource" for "description" property
06-Mar-2017 10:52:38.980 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxActive is not used in DBCP2, use maxTotal instead. maxTotal default value is 8. You have set value of "100" for "maxActive" property, which is being ignored.
06-Mar-2017 10:52:38.981 WARNING [localhost-startStop-1] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Property maxWait is not used in DBCP2 , use maxWaitMillis instead. maxWaitMillis default value is -1. You have set value of "10000" for "maxWait" property, which is being ignored.
06-Mar-2017 10:52:39.009 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
06-Mar-2017 10:52:39.213 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Loading bootstrap properties from /prbootstrap.properties
06-Mar-2017 10:52:39.217 INFO [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
06-Mar-2017 10:52:39.217 INFO [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
06-Mar-2017 10:52:39.218 INFO [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
06-Mar-2017 10:52:39.218 INFO [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
06-Mar-2017 10:52:39.219 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Bootstrap datatables schema: null
06-Mar-2017 10:52:39.267 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Unable to connect to database. Will only use properties from file.
java.sql.SQLException: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2303)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2043)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1543)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapPropertiesFromDB(PRBootstrapDataSource.java:660)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapPropertiesFromDB(PRBootstrapDataSource.java:643)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapProperties(PRBootstrapDataSource.java:620)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapProperties(PRBootstrapDataSource.java:614)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.<clinit>(PRBootstrap.java:119)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.checkForStartup(AppServerBridgeToPega.java:117)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4727)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5189)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:752)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:728)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:734)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:952)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1823)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.postgresql.util.PSQLException: FATAL: the database system is starting up
at org.postgresql.core.v3.ConnectionFactoryImpl.doAuthentication(ConnectionFactoryImpl.java:420)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:195)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:66)
at org.postgresql.jdbc2.AbstractJdbc2Connection.<init>(AbstractJdbc2Connection.java:127)
at org.postgresql.jdbc3.AbstractJdbc3Connection.<init>(AbstractJdbc3Connection.java:29)
at org.postgresql.jdbc3g.AbstractJdbc3gConnection.<init>(AbstractJdbc3gConnection.java:21)
at org.postgresql.jdbc4.AbstractJdbc4Connection.<init>(AbstractJdbc4Connection.java:41)
at org.postgresql.jdbc4.Jdbc4Connection.<init>(Jdbc4Connection.java:24)
at org.postgresql.Driver.makeConnection(Driver.java:414)
at org.postgresql.Driver.connect(Driver.java:282)
at org.apache.tomcat.dbcp.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.tomcat.dbcp.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:257)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2313)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2299)
... 28 more
06-Mar-2017 10:52:39.274 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Archive version [0 ]
06-Mar-2017 10:52:39.274 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine schema defined in allclasses: null
06-Mar-2017 10:52:39.275 INFO [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
06-Mar-2017 10:52:39.277 INFO [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
06-Mar-2017 10:52:39.277 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine classes schema: null
06-Mar-2017 10:52:39.278 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Assembled classes schema: null
06-Mar-2017 10:52:39.279 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
06-Mar-2017 10:52:39.297 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
06-Mar-2017 10:52:39.301 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Will load phase 2 bootstrap from Pega-EngineCode:
06-Mar-2017 10:52:39.320 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. PRMiniLoader - unable to load classes from the database: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
C:\PRPCPersonalEdition\tomcat\webapps\prweb\WEB-INF\lib\boot\prbootphase2.jar (The system cannot find the path specified)
Perhaps executing with a non-standard classpath (e.g. JUnit tests)?
at com.pega.pegarules.internal.bootstrap.PRBootstrap.printConfiguration(PRBootstrap.java:772)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:665)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
... 21 more
06-Mar-2017 10:52:39.374 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap.
============ PegaRULES Bootstrap Configuration ============
Date: Mon Mar 06 10:52:39 IST 2017
Java Version: Oracle Corporation 1.8.0_111
Configuration: file:/C:/PRPCPersonalEdition/tomcat/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode:
(!) Unable to use given database configuration
(!) Unable to locate classes on filesystem
=============== End Bootstrap Configuration ===============
Unable to load phase 2 bootstrap class: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
06-Mar-2017 10:52:39.378 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:388)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.loadPhase2BootstrapClass(PRBootstrap.java:720)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:662)
06-Mar-2017 10:52:39.379 SEVERE [localhost-startStop-1] com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega. Problem during method invocation (contextInitialized)
java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.web.servlet.WebAppLifeCycleListener
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getImplementationOf(PRBootstrap.java:208)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getEntry(PRBootstrap.java:324)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getMethod(PRBootstrap.java:304)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:409)
06-Mar-2017 10:52:39.380 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
06-Mar-2017 10:52:39.381 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/prweb] startup failed due to previous errors
06-Mar-2017 10:52:39.383 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
06-Mar-2017 10:52:39.401 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
06-Mar-2017 10:52:39.401 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Will load phase 2 bootstrap from Pega-EngineCode:
06-Mar-2017 10:52:39.421 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. PRMiniLoader - unable to load classes from the database: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextDestroyed(WebAppLifeCycleListenerBoot.java:67)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4774)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5411)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:226)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154)
... 22 more
06-Mar-2017 10:52:39.482 1050 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap.
Pega-EngineCode:
06-Mar-2017 10:52:39.483 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Error initializing PRAppLoader
06-Mar-2017 10:52:39.484 SEVERE [localhost-startStop-1] com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega. Problem during method invocation (contextDestroyed)
06-Mar-2017 10:52:39.498 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\PRPCPersonalEdition\tomcat\webapps\prweb.war has finished in 1,177 ms
06-Mar-2017 10:52:39.499 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\docs
06-Mar-2017 10:52:39.616 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\docs has finished in 117 ms
06-Mar-2017 10:52:39.617 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\examples
06-Mar-2017 10:52:40.340 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\examples has finished in 723 ms
06-Mar-2017 10:52:40.344 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\host-manager
06-Mar-2017 10:52:40.464 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\host-manager has finished in 121 ms
06-Mar-2017 10:52:40.467 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\manager
06-Mar-2017 10:52:40.624 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\manager has finished in 157 ms
06-Mar-2017 10:52:40.627 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\ROOT
06-Mar-2017 10:52:40.716 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\PRPCPersonalEdition\tomcat\webapps\ROOT has finished in 88 ms
06-Mar-2017 10:52:40.720 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler [http-nio-8080]
06-Mar-2017 10:52:40.729 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler [ajp-nio-9009]
06-Mar-2017 10:52:40.732 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 2471 ms
Hi Bharath,
For these type of issues screenshot will not give useful information. Please make sure you will share the complete stack trace while reporting these type of issues.
Do you have any antivirus installed in this system ? .
Hi Bharath,
If you have antivirus installed in your system, disable/uninstall the same.
Also,perform below steps:
1) Clear the temp cache of your laptop %Temp%
2) Clear your browser cache.
3) Click on 'PRPC 7.2.2 startup' and wait for approx 2 or 3 min
4) Click on 'PRPC 7.2.2 Login'
Jk Technosoft
server starting
server starting
... 28 more
... 21 more
Pega-EngineCode:
... 22 more
Pega-EngineCode:
Hi Bharath,
Can you please confirm whether below steps has been performed ? Else perform the following steps and let me know the result.
1) If antivirus is in enabled status, disable it.
2) If Skype is installed, uninstall it.
3) Click on 'PRPC 7.2.2 shutdown'
4) Clear the temp cache of your laptop %Temp%
5) Click on 'PRPC 7.2.2 startup' and wait for approx 2 or 3 min
6) Click on 'PRPC 7.2.2 Login'
Jk Technosoft
That's already i did. But it is not working. Thanks for your help.
Hi Bharath,
Can you please share the screenshot of your system like below. I want to see which all application get started when your OS is loaded.You can execute msconfig command in run and navigate to startup tab.
Jk Technosoft
I am not getting the startup like this. If i try to open the startup it is redirecting to the task manager startup.
Can you please share me the screenshot?
Vachan Chauhan
J.P. Morgan Services India PVT Ltd
Link which I noticed of similar error have a look:
https://pdn.pega.com/community/pega-product-support/question/404-error-occuring-while-logging-prpc
Jk Technosoft
I went through it already before posting my post. It seems not working as well.
Jk Technosoft
Thanks Bharath for the update. FYI, I have tried to reproduce this issue locally, but no luck.
