Error on logs for
Hi Team,
Recently we upgraded our instance to pega 8.8.1v and we started observing below errors on our logs.
Could you share some solution to resolve these errors.
setting initservices/dnode is not present in PrConfigSettingsRegistry.
The setting initservices/vbd is not present in PrConfigSettingsRegistry.
Hi Team,
2023-03-29 05:20:17,269 [til LISTENER_STARTUP] [ STANDARD] [ ] [ ] ( basic.config.SettingsImpl) ERROR - The setting initservices/dnode is not present in PrConfigSettingsRegistry. API is depreciated. Please use new API to get the setting information.
java.lang.Exception: Information : Setting does not exist in PrConfigSetting enum.
at com.pega.pegarules.exec.internal.basic.config.SettingsImpl.logMessageForDepreciatedAPI(SettingsImpl.java:803) ~[prprivate-exec.jar:?]
2023-03-29 05:20:25,207 [til LISTENER_STARTUP] [ STANDARD] [ ] [ ] ( basic.config.SettingsImpl) ERROR - The setting initservices/vbd is not present in PrConfigSettingsRegistry. API is depreciated. Please use new API to get the setting information.
What exactly values need to set for these Application settings !!
Pega-Engine ==> prconfig/initservices/dnode/default
Pega-Engine ==> prconfig/initservices/vbd/default
