Error in logs for initservices/dnode & vbd is not present in PrConfigSettingsRegistry.
Hi Team,
Recently we upgraded our instance to pega 8.8.1v and we started observing below errors on our logs.
Could you share some solution to resolve these errors and if we need to set these Application settings !! then what was the default values !
Pega-Engine ==> prconfig/initservices/dnode/default
Pega-Engine ==> prconfig/initservices/vbd/default
Error in logs -
Hi Team,
Error in logs -
2023-03-29 05:20:17,269 [til LISTENER_STARTUP] [ STANDARD] [ ] [ ] ( basic.config.SettingsImpl) ERROR - The setting initservices/dnode is not present in PrConfigSettingsRegistry. API is depreciated. Please use new API to get the setting information.
java.lang.Exception: Information : Setting does not exist in PrConfigSetting enum.
at com.pega.pegarules.exec.internal.basic.config.SettingsImpl.logMessageForDepreciatedAPI(SettingsImpl.java:803) ~[prprivate-exec.jar:?]
2023-03-29 05:20:25,207 [til LISTENER_STARTUP] [ STANDARD] [ ] [ ] ( basic.config.SettingsImpl) ERROR - The setting initservices/vbd is not present in PrConfigSettingsRegistry. API is depreciated. Please use new API to get the setting information.
