Getting Error in Logs
Hi Team,
I am gettting the below error in logs and my Server going down always. I suspect the following error is causing my server to go down
( internal.access.Opener) ERROR - There was a problem opening a database instance SYSTEM-USER-MYRULES INDIVIDUAL!000######!WORKTAB
com.pega.pegarules.pub.database.ConnectionException: There was a problem opening a database instance SYSTEM-USER-MYRULES INDIVIDUAL!000######!WORKTAB: code: 17008 SQLState: 08003 Message: Closed Connection
Please help me to find out the reason for this Error. Please share your resolution if you also came accross the same issue.
Thanks in Advance.
