Getting error when logging into the enviornment
We are using Pega 8.1.3 with PostGreSQL. We are seeing intermittent login issues on our system while logging in using SAML based SSO. When hit the login URL it takes lot of time to load and we will just see a blank page for 5-10 mins. Some times the page loads and sometimes we get error "there was an issue, please contact your administrator". Also, We see the below error in the logs.
com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find a 'RULE-OBJ-WHEN' with the name 'PZISACOVERAGESESSIONACTIVEFORTHISREQUESTOR' that applies to 'Data-Admin-Operator-ID'. There were 1 rules with this name in the rulebase, but none matched this request. The 1 rules named 'PZISACOVERAGESESSIONACTIVEFORTHISREQUESTOR' defined in the rulebase are:
1 unrelated to applies-to class 'Data-Admin-Operator-ID', for example: 'Pega-Landing-Application-Coverage'.
Has someone seen this issue earlier? Can you someone let me know how to troubleshoot this issue?
Manju
