Capgemini
Last activity: 23 Nov 2017 6:56 EST
Email listner error count is increasing with time with error in log
We are facing problem as the error count is getting increased in SMA for email listener with every run with below in log. The log size is overflowing with repetitive error.
"Caught javax.mail.MessagingException when attempting to get new messages
javax.mail.MessagingException: Connection reset;
nested exception is:
java.net.SocketException: Connection reset
at com.sun.mail.imap.IMAPStore.protocolConnect(IMAPStore.java:726)
at javax.mail.Service.connect(Service.java:364)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.openMailFolder(EmailListener.java:3284)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.emailReceive(EmailListener.java:3421)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.oneIteration(EmailListener.java:2805)
at com.pega.pegarules.integration.engine.internal.services.email.EmailListener.run_(EmailListener.java:2676)
at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:454)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.processAsyncTask(AsyncServant.java:213)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.AsyncServant.invoke(AsyncServant.java:167)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:327)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:270)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.GeneratedMethodAccessor77.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56)
at java.lang.reflect.Method.invoke(Method.java:620)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:246)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRAsync.processRequest(PRAsync.java:155)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.AsyncTask.run(AsyncTask.java:64)
at com.pega.pegarules.session.internal.engineinterface.etier.asynchbeans.RunnableWrapper.run(RunnableWrapper.java:71)
at com.ibm.ws.asynchbeans.J2EEContext$RunProxy.run(J2EEContext.java:271)
at java.security.AccessController.doPrivileged(AccessController.java:422)
at javax.security.auth.Subject.doAs(Subject.java:494)
at com.ibm.websphere.security.auth.WSSubject.doAs(WSSubject.java:133)
at com.ibm.websphere.security.auth.WSSubject.doAs(WSSubject.java:91)
at com.ibm.ws.asynchbeans.J2EEContext$DoAsProxy.run(J2EEContext.java:338)
at java.security.AccessController.doPrivileged(AccessController.java:452)
at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:806)
at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecutionContextImpl.java:222)
at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:206)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892)
Caused by:
at java.net.SocketInputStream.read(SocketInputStream.java:208)
at java.net.SocketInputStream.read(SocketInputStream.java:134)
at com.ibm.jsse2.a.a(a.java:51)
at com.ibm.jsse2.a.a(a.java:148)
at com.ibm.jsse2.qc.a(qc.java:844)
at com.ibm.jsse2.qc.a(qc.java:847)
at com.ibm.jsse2.e.read(e.java:8)
at com.sun.mail.util.TraceInputStream.read(TraceInputStream.java:124)
at java.io.BufferedInputStream.fill(BufferedInputStream.java:247)
at java.io.BufferedInputStream.read(BufferedInputStream.java:266)
at com.sun.mail.iap.ResponseInputStream.readResponse(ResponseInputStream.java:95)
at com.sun.mail.iap.Response.<init>(Response.java:109)
at com.sun.mail.imap.protocol.IMAPResponse.<init>(IMAPResponse.java:60)
at com.sun.mail.imap.protocol.IMAPProtocol.readResponse(IMAPProtocol.java:320)
at com.sun.mail.iap.Protocol.<init>(Protocol.java:124)
at com.sun.mail.imap.protocol.IMAPProtocol.<init>(IMAPProtocol.java:121)
at com.sun.mail.imap.IMAPStore.newIMAPProtocol(IMAPStore.java:746)
at com.sun.mail.imap.IMAPStore.protocolConnect(IMAPStore.java:689)
... 34 more" ..
But surprisingly it is working fine whenever any incoming email is available in the mailbox. Did anybody face this issue earlier?
***23/11/2017: Updated by moderator: Lochan to close post as issue is no longer under investigation***
