Last activity: 18 Jul 2017 10:48 EDT
Error while trying to access Node from System Management Application
When I am clicking on the node name on SMA, it throws this error:
MSG:
com.pega.jmx.ui.util.JMXClientException: Fail to instantiate WASJMXConnector
Failed to get mbean server connection
SMA ERROR: Failed to create admin client
ADMC0016E: The system cannot create a SOAP connector to connect to host N/A at port N/A.
Stack Trace:
MSG:
Stack Trace:
com.pega.jmx.ui.util.JMXClientException: Fail to instantiate WASJMXConnector Failed to get mbean server connection SMA ERROR: Failed to create admin client ADMC0016E: The system cannot create a SOAP connector to connect to host N/A at port N/A. at com.pega.jmx.ui.util.JMXClientException.wrap(JMXClientException.java:49) at com.pega.jmx.ui.action.AuthenticateAction.execute(AuthenticateAction.java:346) at com.pega.jmx.ui.action.AuthenticateAction.executeWithoutValidation(AuthenticateAction.java:86) at sun.reflect.GeneratedMethodAccessor347.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37) at java.lang.reflect.Method.invoke(Method.java:611) at com.opensymphony.xwork2.DefaultActionInvocation.invokeAction(DefaultActionInvocation.java:450) at com.opensymphony.xwork2.DefaultActionInvocation.invokeActionOnly(DefaultActionInvocation.java:289) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:252) at org.apache.struts2.interceptor.DeprecationInterceptor.intercept(DeprecationInterceptor.java:41) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at org.apache.struts2.interceptor.debugging.DebuggingInterceptor.intercept(DebuggingInterceptor.java:256) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at com.opensymphony.xwork2.interceptor.DefaultWorkflowInterceptor.doIntercept(DefaultWorkflowInterceptor.java:167) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:100) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at com.opensymphony.xwork2.interceptor.ConversionErrorInterceptor.intercept(ConversionErrorInterceptor.java:138) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246)
Surprisingly, this works for some and for some others, it doesn't. As we all know, we can access SMA from here: XXX/prsysmgmt/getnodes.do (XXX is the host name and port). When I try to access SMA even from this link, it behaves similarly. For some other users (Without logging into PRPC), this URL produces desired result and shows them everything related to a node, when they click on the node name.
Can anybody please help?
Thanks.
***Updated by moderator: Lochan to close post***
