Murex (SAS)
LB
Last activity: 15 Jun 2016 2:38 EDT
PRPC System Management Node not found
Use the "+" icon to add the node providing all of the connection details. Once done; the node will show up under the 'Node' header.
PEG
Could you please add a node by clicking + button on top?
Murex (SAS)
LB
hello guys, thank you for your replies.
the problem is from the client side. From the system side the node appears normally but the end users are not able to see the node
Can you please elaborate more on what you mean by 'the problem is from client side and from the system side node appears normally? Provide some screen prints if possible.
Murex (SAS)
LB
Hi Bachir,
When a normal user tries to click on add node button ( + icon), is he able to click and add the node?
Bachir,
Is the other user assigned the PegaDiagnosticUser role?
Murex (SAS)
LB
problem solved my friends, the user was also able to add the node by him self .
thanks a lot for your contribution
