Overlap issue in OOTB Dropdown control with IE
Our client is complaining because OOTB dropdowns are presenting overlaping issues with IE.
Usually the very first time you are using the drop-down values are presented below the field itself. However, if you select a value for example in the middle of the list, and then come back again to the drop-down the values are not presented below, value are presented overlapping the field.
Correct drop-down behavior:
Incorrect drop-down behavior:
This is reproducible using Pega 7.1.7 and Pega 7.1.9. Only with IE. Anyone knows if is there a fix or HFix for that?
