New setup of Pega 7.1.9 and move entire code base from Cloud environment.
We have our current application code base in the cloud base. We are planning to setup our own in-premise server and move the code base. What will be the best approach?
1st Approach:
Take back of the PegaRules and PegaData schema from the existing cloud env. Execute the DDLs in the new in-premise database. Configure the application server and connect to the schema. Deploy the archives.
2nd Approach:
Create the new database schema. Do the rulebase loading. Configure the application server and connect to the schema and deploy the archive. Take RAPs for the application instance from the cloud and deploy the same.
Please suggest. Also, Would be great if you highlight the positives and the negatives of both the aproach.
Thanks!
Message was edited by: Marissa Rogers - added category
