Infosys Ltd
Last activity: 19 Dec 2017 5:41 EST
Issue in Update of Pega to 7.3.1 from pega 7.1.9
I am facing the following issue when I have updated the system from Pega 7.1.9 to ega 7.3.1:
"jboss.naming.context.java.comp.prpc_j2ee14_jboss61JBM.prbeans.Database.env.jdbc.AdminPegaRULES is missing [jboss.naming.context.java.jdbc.PegaRULES]",
"jboss.naming.context.java.comp.prpc_j2ee14_jboss61JBM.prbeans.EngineCMT.env.jdbc.AdminPegaRULES is missing [jboss.naming.context.java.jdbc.PegaRULES]",
"jboss.naming.context.java.comp.prpc_j2ee14_jboss61JBM.prbeans.LockManager.env.jdbc.AdminPegaRULES is missing [jboss.naming.context.java.jdbc.PegaRULES]",
Please let me know the resolution for this. Thanks.
Infosys Ltd
The issue is while deploying EAR file.
It seems you have to create another DataSource with Name AdminPegaRULES
<datasource jta="false" jndi-name="java:/jdbc/AdminPegaRULES" poolname="AdminPegaRULES"
enabled="true" use-ccm="false">
<connection-url>jdbc:oracle:thin:@//localhost:1521/service-name-orSID</connection-url>
<driver-class>oracle.jdbc.OracleDriver</driver-class>
<driver>oracle</driver>
<security>
<user-name>user_name</user-name>
<password>password</password>
</security>
<validation>
<validate-on-match>false</validate-on-match>
<background-validation>false</background-validation>
</validation>
<statement>
<share-prepared-statements>false</share-prepared-statements>
</statement>
</datasource>
Infosys Ltd
We don’t have any admin user. And its sql Server.
Above was an example for oracle, but can be adapted for SQL server by making driver and other necessary changes.
However below is working example for me
<?xml version='1.0' encoding='UTF-8'?>
<server xmlns="urn:jboss:domain:1.7">
<extensions>
<extension module="org.jboss.as.clustering.infinispan"/>
<extension module="org.jboss.as.cmp"/>
<extension module="org.jboss.as.connector"/>
<extension module="org.jboss.as.deployment-scanner"/>
<extension module="org.jboss.as.ee"/>
<extension module="org.jboss.as.ejb3"/>
<extension module="org.jboss.as.jacorb"/>
<extension module="org.jboss.as.jaxr"/>
<extension module="org.jboss.as.jaxrs"/>
<extension module="org.jboss.as.jdr"/>
<extension module="org.jboss.as.jmx"/>
<extension module="org.jboss.as.jpa"/>
<extension module="org.jboss.as.jsf"/>
<extension module="org.jboss.as.jsr77"/>
<extension module="org.jboss.as.logging"/>
<extension module="org.jboss.as.mail"/>
<extension module="org.jboss.as.messaging"/>
<extension module="org.jboss.as.naming"/>
<extension module="org.jboss.as.pojo"/>
<extension module="org.jboss.as.remoting"/>
<extension module="org.jboss.as.sar"/>
<extension module="org.jboss.as.security"/>
<extension module="org.jboss.as.threads"/>
<extension module="org.jboss.as.transactions"/>
<extension module="org.jboss.as.web"/>
<extension module="org.jboss.as.webservices"/>
<extension module="org.jboss.as.weld"/>
</extensions>
<management>
<security-realms>
<security-realm name="ManagementRealm">
<authentication>
<local default-user="$local" skip-group-loading="true"/>
<properties path="mgmt-users.properties" relative-to="jboss.server.config.dir"/>
</authentication>
<authorization map-groups-to-roles="false">
<properties path="mgmt-groups.properties" relative-to="jboss.server.config.dir"/>
</authorization>
</security-realm>
<security-realm name="ApplicationRealm">
<authentication>
<local default-user="$local" allowed-users="*" skip-group-loading="true"/>
<properties path="application-users.properties" relative-to="jboss.server.config.dir"/>
</authentication>
<authorization>
<properties path="application-roles.properties" relative-to="jboss.server.config.dir"/>
</authorization>
</security-realm>
</security-realms>
<audit-log>
<formatters>
<json-formatter name="json-formatter"/>
</formatters>
<handlers>
<file-handler name="file" formatter="json-formatter" path="audit-log.log" relative-to="jboss.server.data.dir"/>
</handlers>
<logger log-boot="true" log-read-only="false" enabled="false">
<handlers>
<handler name="file"/>
</handlers>
</logger>
</audit-log>
<management-interfaces>
<native-interface security-realm="ManagementRealm">
<socket-binding native="management-native"/>
</native-interface>
<http-interface security-realm="ManagementRealm">
<socket-binding http="management-http"/>
</http-interface>
</management-interfaces>
<access-control provider="simple">
<role-mapping>
<role name="SuperUser">
<include>
<user name="$local"/>
</include>
</role>
</role-mapping>
</access-control>
</management>
<profile>
<subsystem xmlns="urn:jboss:domain:logging:1.5">
<console-handler name="CONSOLE">
<level name="INFO"/>
<formatter>
<named-formatter name="COLOR-PATTERN"/>
</formatter>
</console-handler>
<periodic-rotating-file-handler name="FILE" autoflush="true">
<formatter>
<named-formatter name="PATTERN"/>
</formatter>
<file relative-to="jboss.server.log.dir" path="server.log"/>
<suffix value=".yyyy-MM-dd"/>
<append value="true"/>
</periodic-rotating-file-handler>
<logger category="com.arjuna">
<level name="WARN"/>
</logger>
<logger category="org.apache.tomcat.util.modeler">
</logger>
<logger category="org.jboss.as.config">
<level name="DEBUG"/>
</logger>
<logger category="sun.rmi">
</logger>
<logger category="jacorb">
</logger>
<logger category="jacorb.config">
<level name="ERROR"/>
</logger>
<root-logger>
<handlers>
<handler name="CONSOLE"/>
<handler name="FILE"/>
</handlers>
</root-logger>
<formatter name="PATTERN">
<pattern-formatter pattern="%d{HH:mm:ss,SSS} %-5p [%c] (%t) %s%E%n"/>
</formatter>
<formatter name="COLOR-PATTERN">
<pattern-formatter pattern="%K{level}%d{HH:mm:ss,SSS} %-5p [%c] (%t) %s%E%n"/>
</formatter>
</subsystem>
<subsystem xmlns="urn:jboss:domain:cmp:1.1"/>
<subsystem xmlns="urn:jboss:domain:datasources:1.2">
<datasources>
<datasource jndi-name="java:jboss/datasources/ExampleDS" pool-name="ExampleDS" enabled="true" use-java-context="true">
<connection-url>jdbc:h2:mem:test;DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE</connection-url>
<driver>h2</driver>
<security>
<user-name>sa</user-name>
<password>sa</password>
</security>
</datasource>
<datasource jta="false" jndi-name="java:/jdbc/PegaRULES" pool-name="PegaRULES" enabled="true" use-ccm="false">
<connection-url>jdbc:sqlserver://localhost:1433;databaseName=PRPC_73_JBOSS;selectMethod=cursor;sendStringParametersAsUnicode=false</connection-url>
<driver-class>com.microsoft.sqlserver.jdbc.SQLServerDriver</driver-class>
<driver>mssql</driver>
<pool>
<max-pool-size>100</max-pool-size>
</pool>
<security>
<user-name>PRPC_73_JBOSS</user-name>
<password>PRPC_73_JBOSS</password>
</security>
<validation>
</validation>
<statement>
</statement>
</datasource>
<datasource jta="false" jndi-name="java:/jdbc/AdminPegaRULES" pool-name="AdminPegaRULES" enabled="true" use-ccm="false">
<pool>
</pool>
<security>
</security>
<validation>
</validation>
<statement>
</statement>
</datasource>
<drivers>
<driver name="h2" module="com.h2database.h2">
<xa-datasource-class>org.h2.jdbcx.JdbcDataSource</xa-datasource-class>
</driver>
<driver name="mssql" module="com.mssql">
</driver>
<driver name="microsoft" module="com.mssql"/>
</drivers>
</datasources>
</subsystem>
<subsystem xmlns="urn:jboss:domain:deployment-scanner:1.1">
<deployment-scanner path="deployments" relative-to="jboss.server.base.dir" scan-interval="5000"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:ee:1.2">
<spec-descriptor-property-replacement>false</spec-descriptor-property-replacement>
<jboss-descriptor-property-replacement>true</jboss-descriptor-property-replacement>
<annotation-property-replacement>false</annotation-property-replacement>
</subsystem>
<subsystem xmlns="urn:jboss:domain:ejb3:1.5">
<session-bean>
<stateless>
<bean-instance-pool-ref pool-name="slsb-strict-max-pool"/>
</stateless>
<stateful default-access-timeout="5000" cache-ref="simple"/>
<singleton default-access-timeout="5000"/>
</session-bean>
<mdb>
<resource-adapter-ref resource-adapter-name="${ejb.resource-adapter-name:hornetq-ra}"/>
<bean-instance-pool-ref pool-name="mdb-strict-max-pool"/>
</mdb>
<pools>
<bean-instance-pools>
<strict-max-pool name="slsb-strict-max-pool" max-pool-size="20" instance-acquisition-timeout="5" instance-acquisition-timeout-unit="MINUTES"/>
<strict-max-pool name="mdb-strict-max-pool" max-pool-size="20" instance-acquisition-timeout="5" instance-acquisition-timeout-unit="MINUTES"/>
</bean-instance-pools>
</pools>
<caches>
<cache name="simple" aliases="NoPassivationCache"/>
<cache name="passivating" passivation-store-ref="file" aliases="SimpleStatefulCache"/>
</caches>
<passivation-stores>
<file-passivation-store name="file"/>
</passivation-stores>
<async thread-pool-name="default"/>
<timer-service thread-pool-name="default" default-data-store="default-file-store">
<data-stores>
<file-data-store name="default-file-store" path="timer-service-data" relative-to="jboss.server.data.dir"/>
</data-stores>
</timer-service>
<remote connector-ref="remoting-connector" thread-pool-name="default"/>
<thread-pools>
<thread-pool name="default">
<max-threads count="10"/>
<keepalive-time time="100" unit="milliseconds"/>
</thread-pool>
</thread-pools>
<iiop enable-by-default="false" use-qualified-name="false"/>
<default-security-domain value="other"/>
<default-missing-method-permissions-deny-access value="true"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:infinispan:1.5">
<cache-container name="web" aliases="standard-session-cache" default-cache="local-web" module="org.jboss.as.clustering.web.infinispan">
<local-cache name="local-web" batching="true">
<file-store passivation="false" purge="false"/>
</local-cache>
</cache-container>
<cache-container name="hibernate" default-cache="local-query" module="org.jboss.as.jpa.hibernate:4">
<local-cache name="entity">
<transaction mode="NON_XA"/>
<eviction strategy="LRU" max-entries="10000"/>
<expiration max-idle="100000"/>
</local-cache>
<local-cache name="local-query">
<transaction mode="NONE"/>
</local-cache>
<local-cache name="timestamps">
<eviction strategy="NONE"/>
</local-cache>
</cache-container>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jacorb:1.4">
<orb socket-binding="jacorb" ssl-socket-binding="jacorb-ssl">
<initializers security="identity" transactions="spec"/>
</orb>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jaxr:1.1">
<connection-factory jndi-name="java:jboss/jaxr/ConnectionFactory"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jaxrs:1.0"/>
<subsystem xmlns="urn:jboss:domain:jca:1.1">
<archive-validation enabled="true" fail-on-error="true" fail-on-warn="false"/>
<bean-validation enabled="true"/>
<default-workmanager>
<short-running-threads>
<core-threads count="50"/>
<queue-length count="50"/>
<max-threads count="50"/>
<keepalive-time time="10" unit="seconds"/>
</short-running-threads>
<long-running-threads>
</long-running-threads>
</default-workmanager>
<cached-connection-manager/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jdr:1.0"/>
<subsystem xmlns="urn:jboss:domain:jmx:1.3">
<expose-resolved-model/>
<expose-expression-model/>
<remoting-connector/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jpa:1.1">
<jpa default-datasource="" default-extended-persistence-inheritance="DEEP"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:jsf:1.0"/>
<subsystem xmlns="urn:jboss:domain:jsr77:1.0"/>
<subsystem xmlns="urn:jboss:domain:mail:1.2">
<mail-session name="default" jndi-name="java:jboss/mail/Default">
<smtp-server outbound-socket-binding-ref="mail-smtp"/>
</mail-session>
</subsystem>
<subsystem xmlns="urn:jboss:domain:messaging:1.4">
<hornetq-server>
<persistence-enabled>true</persistence-enabled>
<security-enabled>false</security-enabled>
<journal-type>NIO</journal-type>
<journal-min-files>2</journal-min-files>
<connectors>
<netty-connector name="netty" socket-binding="messaging"/>
<netty-connector name="netty-throughput" socket-binding="messaging-throughput">
<param key="batch-delay" value="50"/>
</netty-connector>
<in-vm-connector name="in-vm" server-id="0"/>
</connectors>
<acceptors>
<netty-acceptor name="netty" socket-binding="messaging"/>
<netty-acceptor name="netty-throughput" socket-binding="messaging-throughput">
<param key="direct-deliver" value="false"/>
</netty-acceptor>
<in-vm-acceptor name="in-vm" server-id="0"/>
</acceptors>
<security-settings>
<security-setting match="#">
<permission type="send" roles="guest"/>
<permission type="consume" roles="guest"/>
<permission type="createNonDurableQueue" roles="guest"/>
<permission type="deleteNonDurableQueue" roles="guest"/>
</security-setting>
</security-settings>
<address-settings>
<address-setting match="#">
<dead-letter-address>jms.queue.DLQ</dead-letter-address>
<expiry-address>jms.queue.ExpiryQueue</expiry-address>
<redelivery-delay>0</redelivery-delay>
<max-size-bytes>10485760</max-size-bytes>
<page-size-bytes>2097152</page-size-bytes>
<address-full-policy>PAGE</address-full-policy>
<message-counter-history-day-limit>10</message-counter-history-day-limit>
</address-setting>
</address-settings>
<jms-connection-factories>
<connection-factory name="InVmConnectionFactory">
<connectors>
<connector-ref connector-name="in-vm"/>
</connectors>
<entries>
<entry name="java:/ConnectionFactory"/>
</entries>
</connection-factory>
<connection-factory name="RemoteConnectionFactory">
<connectors>
<connector-ref connector-name="netty"/>
</connectors>
<entries>
<entry name="java:jboss/exported/jms/RemoteConnectionFactory"/>
</entries>
<pooled-connection-factory name="hornetq-ra">
<transaction mode="xa"/>
<connectors>
</connectors>
<entries>
<entry name="java:/JmsXA"/>
</entries>
</pooled-connection-factory>
<pooled-connection-factory name="AsyncConnectionFactory">
<connectors>
</connectors>
<entries>
<entry name="java:/jms/PRAsyncTCF"/>
</entries>
</jms-connection-factories>
<jms-destinations>
<jms-queue name="ExpiryQueue">
<entry name="java:/jms/queue/ExpiryQueue"/>
</jms-queue>
<jms-queue name="DLQ">
<entry name="java:/jms/queue/DLQ"/>
</jms-queue>
</jms-destinations>
</hornetq-server>
</subsystem>
<subsystem xmlns="urn:jboss:domain:naming:1.4">
<bindings>
<simple name="java:/prconfig/database/databases/PegaRULES/defaultSchema" value="RULES"/>
<simple name="java:/prconfig/database/databases/PegaDATA/defaultSchema" value="DATA"/>
<simple name="java:/url/pega/none" value="file:/nul"/>
</bindings>
</subsystem>
<subsystem xmlns="urn:jboss:domain:pojo:1.0"/>
<subsystem xmlns="urn:jboss:domain:remoting:1.2">
<connector name="remoting-connector" socket-binding="remoting" security-realm="ApplicationRealm"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:resource-adapters:1.1"/>
<subsystem xmlns="urn:jboss:domain:sar:1.0"/>
<subsystem xmlns="urn:jboss:domain:security:1.2">
<security-domains>
<security-domain name="other" cache-type="default">
<authentication>
<login-module code="Remoting" flag="optional">
<module-option name="password-stacking" value="useFirstPass"/>
</login-module>
<login-module code="RealmDirect" flag="required">
</login-module>
</authentication>
</security-domain>
<security-domain name="jboss-web-policy" cache-type="default">
<authorization>
<policy-module code="Delegating" flag="required"/>
</authorization>
</security-domain>
<security-domain name="jboss-ejb-policy" cache-type="default">
<authorization>
</authorization>
</security-domain>
</security-domains>
</subsystem>
<subsystem xmlns="urn:jboss:domain:threads:1.1"/>
<subsystem xmlns="urn:jboss:domain:transactions:1.5">
<core-environment>
<process-id>
<uuid/>
</process-id>
</core-environment>
<recovery-environment socket-binding="txn-recovery-environment" status-socket-binding="txn-status-manager"/>
<coordinator-environment default-timeout="300"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:web:2.2" default-virtual-server="default-host" native="false">
<connector name="http" protocol="HTTP/1.1" scheme="http" socket-binding="http"/>
<virtual-server name="default-host" enable-welcome-root="true">
<alias name="localhost"/>
<alias name="example.com"/>
</virtual-server>
</subsystem>
<subsystem xmlns="urn:jboss:domain:webservices:1.2">
<modify-wsdl-address>true</modify-wsdl-address>
<wsdl-host>${jboss.bind.address:127.0.0.1}</wsdl-host>
<endpoint-config name="Standard-Endpoint-Config"/>
<endpoint-config name="Recording-Endpoint-Config">
<pre-handler-chain name="recording-handlers" protocol-bindings="##SOAP11_HTTP ##SOAP11_HTTP_MTOM ##SOAP12_HTTP ##SOAP12_HTTP_MTOM">
<handler name="RecordingHandler" class="org.jboss.ws.common.invocation.RecordingServerHandler"/>
</pre-handler-chain>
</endpoint-config>
<client-config name="Standard-Client-Config"/>
</subsystem>
<subsystem xmlns="urn:jboss:domain:weld:1.0"/>
</profile>
<interfaces>
<interface name="management">
<inet-address value="${jboss.bind.address.management:127.0.0.1}"/>
</interface>
<interface name="public">
<inet-address value="${jboss.bind.address:127.0.0.1}"/>
</interface>
<interface name="unsecure">
<inet-address value="${jboss.bind.address.unsecure:127.0.0.1}"/>
</interface>
</interfaces>
<socket-binding-group name="standard-sockets" default-interface="public" port-offset="${jboss.socket.binding.port-offset:0}">
<socket-binding name="management-native" interface="management" port="${jboss.management.native.port:9999}"/>
<socket-binding name="management-http" interface="management" port="${jboss.management.http.port:9990}"/>
<socket-binding name="management-https" interface="management" port="${jboss.management.https.port:9443}"/>
<socket-binding name="ajp" port="8009"/>
<socket-binding name="http" port="8080"/>
<socket-binding name="https" port="8443"/>
<socket-binding name="jacorb" interface="unsecure" port="3528"/>
<socket-binding name="jacorb-ssl" interface="unsecure" port="3529"/>
<socket-binding name="messaging" port="5445"/>
<socket-binding name="messaging-group" port="0" multicast-address="${jboss.messaging.group.address:231.7.7.7}" multicast-port="${jboss.messaging.group.port:9876}"/>
<socket-binding name="messaging-throughput" port="5455"/>
<socket-binding name="remoting" port="4447"/>
<socket-binding name="txn-recovery-environment" port="4712"/>
<socket-binding name="txn-status-manager" port="4713"/>
<outbound-socket-binding name="mail-smtp">
<remote-destination host="localhost" port="25"/>
</outbound-socket-binding>
</socket-binding-group>
<deployments>
<deployment name="prpc_j2ee14_jboss61JBM.ear" runtime-name="prpc_j2ee14_jboss61JBM.ear">
<content sha1="bdc8455100a5e41a1431b69cb5f36778b75a6253"/>
</deployment>
<deployment name="prsysmgmt.war" runtime-name="prsysmgmt.war">
<content sha1="c9be05a696e61588c28225dcf129703956ab8ad9"/>
</deployment>
<deployment name="prhelp.war" runtime-name="prhelp.war">
<content sha1="2f2017db6894b13cf4b243194378a238a8d6fded"/>
</deployment>
</deployments>
</server>
Infosys Ltd
Recommended change is in standalone-full.xml right? Also, may I know the way you deployed the ear/war files? I mean how did you deploy them? The other issue is that I want to take the backup of prconfig, prlogging and other files which I don’t see in the app server folder structure.
Hi Sikhar,
Yes the change can be made in Standalone-full.xml.
I have deployed the war files using Jboss Console using deploy option. There is also a command line to do so(Refer Jboss Documentation)
You can find config files at 115290_Pega722\archives\prpc_j2ee14_jboss61JBM.ear\APP-INF\lib\prresources.jar\
You can open it with 7ZIP and the make changes and save it.
Ujjwal
Infosys Ltd
Which config file is to be modified inside "115290_Pega722\archives\prpc_j2ee14_jboss61JBM.ear\APP-INF\lib\prresources.jar\" ? And if something is modified inside this mentioned location then is the modification required in standalone.xml?
Earlier you asked about where to find prConfig and prLogging xml files.
You can get those in prresources.jar
Well If you change the dataSource name in prconfig.xml then same should be updated in standalone-full.xml as well.
Infosys Ltd
Can you also please share your jboss.xml? We have the following tags in the jboss.xml file:
<resource-ref>
<res-ref-name>jdbc/AdminPegaRULES</res-ref-name>
<!--resource-name>AdminPegaRULES</resource-name-->
<!-- reference to resource-manager entry -->
<jndi-name>java:/jdbc/PegaRULES</jndi-name>
</resource-ref>
Which according to me means that if ref-name is Admin go and search for this JNDI-NAME which is PegaRules only.
Infosys Ltd
It worked. Thanks for that. But, I was trying to not use what you recommended and also, modify web.xml as mentioned in the Installation Guide of Pega 7.3.1. Could you please help me in understanding what was the issue? How the JBOSS starts up the server and what files and settings it looks for?
Hi Sikhar,
If you are starting your Jboss with standalone.bat --server-config=standalone-full.xml -b 0.0.0.0
You need to make changes to standalone-full.xml.
When Jboss starts it scans the StandAlone-full.xml and then initializes all the subsystems like dataSources, jms and connection pool etc.
Web.xml comes into picture at runtime I think.
Ujjwal
Infosys Ltd
The installation guide of pega 7.3.1 suggests some changes in web.xml but the update guide does not mention about the modifications in web.xml. So, that's why my question was if I make the change to web.xml do I need to make in the standalone or not?
Also, why is the JBOSS looking for AdminPegaRules and from where? It must be mentioned somewhere in the EAR that is making it look for that one?
Hi Shikhar,
Page no 32-36 of this guide recommend to have admin dataSource as well.
https://pdn.pega.com/documents/pega-731-platform-installation-guide-jboss-redhat-eap-and-microsoft-sql-server
I believe changes to web.xml are kept as backup, in case Jboss terminates the DataSource someway.
Ujjwal
