OptumRx
Last activity: 28 Oct 2015 8:17 EDT
Exercise System Installation problem
I can't seem to figure out how to installation the exercise system for Mac. Everytime I download the VM package it is in .exe format. Please help.
Kevin
Kevin,
Use StuffIt Expander to extract the vm.
Once you have it extracted, you'll get a folder two sub-folders: server and applications.
You will need to use a vm player for OS X. The Quick Start Guide available in the Downloading the Exercise System lesson has instructions for how to use VMWare Fusion, but it also includes instructions on how to get started with Parallels or VirtualBox (although VirtualBox is a bit more tricky than what I wrote in that guide, so if that is what you plan on using, let me know and I can provide more details).
The file you will want to run is prpc.vmx in the server sub-folder.
Let me know if you need any more help.
eddie
Oh,
and be warned that there are still some record types in Pega 7 that are only compatabile with IE. You can use the same vm running on your Mac, but you will need to access Pega 7 from IE. I typically start up a Windows vm along with the Pega 7 vm, then use IE long enough to do what I need to do, then go right back to the comfort of OS X.
eddie
OptumRx
Hi Eddie,
Thanks for the quick response. When I clicked on the link to Quick Start Guide under the related section, it loops back to the same webpage. I read in the other post that I have to email selfstudy for the Quick Start Guide guide, is this still true? Thanks
Evin
no, that can't be. Using Chrome, I click that download link and it opens the PDF in a new tab.
I'll send you a private message with a Google Drive link where I have a copy you can download
eddie
United Health Group
for pega6.2 sp2 application, we have recently upgrading our IE's to 11 version and installed hotfixes to support, but while testing when ever we click on the dropdown the background color is getting changed. any suggestions will be helpful.
Varalaxmy.
Varalaxmy,
I'm going to recommend you post this question in the PRPC forum.
The forum we are in now is for questions relating to the Business Architect Essentials course using Pega 7.
It seems the best topic area for your issue is: https://pdn.pega.com/forums/prpc/deployment-installs-upgrades-platforms
eddie
Cigna
For BA 7.1, is there an exercise system available on the cloud?
JP Morgan Chase
Hi Casey,
Did you got the answer to your question as i am also looking for the same.
Thx
Vipul
Cigna
Hi Vipul,
No, I did not get an answer. Sorry, I can't help with that.
Casey
