Capgemini
FR
Last activity: 8 Jan 2020 8:31 EST
Thread switching when moving between interactions tabs
I noticed a problem of context when we switch between the tabs of the interactions.
This problem only exists when there is an open service case ( Intent task ) in each of the interactions.
For example, if you have a task opened in Interaction A and a second task opened in Interaction B (Interaction B active tab), if we go back to the interaction A, the interaction ID that is taken into consideration is that of the B interaction.
If we do not have any open cases in the interactions, the context changes when we switch between the tabs.
Does anyone faced this issue ?
