How does rule resolution execute when switching between apps ?
I have configured one of my application(App2) to allow it to view all the assignments from different applications. (removed pxapplication filter from worklist data page) Now I am wondering about how the rule resolution works in this situation ? For instance, I have a data transform for SOAP requests defined in Work- class on framework ruleset. And then I customize it in Org-Div-App1-Work- class on implementation ruleset. But when I open App1's assignment on App 2, where does PRPC look for the data transfrom ? Under App1-Work and App1 ruleset or App2-Work and App2 ruleset ?
I also would like to ask whether my is my approach is correct ? I mean, I need to allow users to view all his/her assignments and process cases in one screen, not switching apps.
Thank you very much.
Hi @EngincanY,
Thank you for posting your query here.
I have attached a document on how Rule Resolution works.
In your example it will look for the rule in App1 if the assignment has already reached the context of App1. If the operator has access to all the rulesets, your approach is correct.
Priyabharathi
