Perficient
Web Application DropDown Interrogation issue in openspan
Iam facing an issue while interrogating dropdown(PFA) in a webapplication using openspan.i am unable to select the dropdown items.Could you please suggest me on this.
Capgemini Sverige
SE
Can you check the match rules while interrogating?
May be it couldn't able to find the correct matching combination.
Perficient
Hi
i checked in match rules also but i am unable to find the exact matching combination for dropdown.
Capgemini Sverige
SE
You need to go through the js of that page containing dropdown and try with different combination.
Generally in this scenario,go for hit and trial.
Perficient
Hi
we tried the matching rules,the dropdown button is coming as image,when we give the click operation dropdown values are not displaying.
Anyone please help me for this problem.
If you have a control like this that isn't interrogated as a select control, you can look at the html to try to figure out what the selection actually does. You can then write some javascript to take the same action. Sometimes, if you find that you can do the selection with keystrokes you can do a perform click on the control to open the dropdown and then a sendkeys to cause the correct option to be chosen - something like {DOWN 3}{ENTER}. Without the html it is hard to give you anything more concrete than this.
Thaveesha Cabral
Accenture
Hi Jeff,
As discussed previously, we go through the view source of this drop down. Manually when we click this dropdown, list is coming, but in source there is no onclick or keystroke control. I have attached HTML here. Please suggest how to implement.
Susmita
Contra Costa County
Was this issue been resolved? If so, can you please share how it was resolved?
Regards.
Nick
Accenture Solutions Pvt Ltd
Why Does Sendkeys using {DOWN 3} do not for Windows controls of java swing application it works only if we specify {DOWN} in Sendkeys method separately 3 times for the controls like DropDown where SelectItem method of java dropdown control is not working.
