Infosys Ltd
Last activity: 17 Dec 2019 7:52 EST
Web Application Interrogation Issue
Hi, For my project have to launch a URL as a start page in web application . After the URL gets launched it gets navigated to a widget container form. Facing object identification issue in widget container form. Steps mentioned below
Step 1: Start the interrogation mode of web adapter and interrogated fields in widget container form. All the interrogated fields are in Green Tick Mark
Step 2: Interrogation stopped and again started interrogation mode of web adapter .
Step 3: Fields which are identified in earlier session is not identified by pega.
Attached Screenshot for reference.
It is likely that one of your controls is using a match rule which changes every session. You'll need to identify that and update it to be more generic. You can usually determine this by simply interrogating the same controls again next to the ones you did previously and comparing the match rules between them.
