CGI
Last activity: 24 May 2018 4:26 EDT
PRA: Issue in Interrogate the web application
Using Pega Robotics Studio 8.0.1059.0
1 Open the ACMESearchSystem.os project item in a design window.
2 Click Start Interrogation. Interrogation Form is opening and closing. ACME Search System web page is not opened for Interrogatiom
Please find the details below from Studio_Log4Net.txt
INFO | 2018-05-21 18:49:09,871 | 13 | 13 | 8744 | MTA | Web Adapter | ACMESearchSystem | | Starting adapter
DEBUG | 2018-05-21 18:49:09,902 | 13 | 13 | 8744 | MTA | UI Connectors | | | ExpressTranslatorService.EnsureTranslatorsLoaded() - ENTER
INFO | 2018-05-21 18:49:09,902 | 13 | 13 | 8744 | MTA | Adapter Reparenting | ACMESearchSystem | | WindowsAdapterBase.StartProcess: No user control has registered to reparent this adapter
INFO | 2018-05-21 18:49:09,902 | 13 | 13 | 8744 | MTA | Windows Adapter | ACMESearchSystem | | Starting Process - Target: , Path: C:\Program Files (x86)\Internet Explorer\iexplore.exe, Dir: C:\Program Files (x86)\Internet Explorer, Args: -restart -noframemerging -nohangrecovery http://training.openspan.com, Timeout: 10000
INFO | 2018-05-21 18:49:09,933 | rThread | 50 | 8744 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Found internal SetState2
INFO | 2018-05-21 18:49:09,933 | rThread | 50 | 8744 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Calling base...
INFO | 2018-05-21 18:49:09,933 | rThread | 50 | 8744 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Base called
INFO | 2018-05-21 18:49:10,167 | 13 | 13 | 8744 | MTA | Windows Adapter | ACMESearchSystem | OpenSpan.Adapters.Windows.WindowsProcess-17733085 | WindowsProcess.InjectAndResumeProcess: Process C:\Program Files (x86)\Internet Explorer\iexplore.exe started, injected and resumed
INFO | 2018-05-21 18:49:10,417 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_PROCESS_CREATED received
INFO | 2018-05-21 18:49:10,417 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Attaching process 9732 (C:\Program Files (x86)\Internet Explorer\iexplore.exe) to WindowsProcess object
INFO | 2018-05-21 18:49:10,417 | 13 | 13 | 8744 | MTA | Windows Adapter | ACMESearchSystem | | Started Process - Name: iexplore.exe
INFO | 2018-05-21 18:49:10,417 | 13 | 13 | 8744 | MTA | Web Adapter | ACMESearchSystem | | Adapter started
INFO | 2018-05-21 18:49:10,417 | rThread | 50 | 8744 | STA | Adapter Reparenting | ACMESearchSystem | | WindowsReparentingManager.ProcessCreated: Process (iexplore.exe) created [Reparent=False]
ERROR | 2018-05-21 18:49:10,432 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | OpenSpan.Adapters.Windows.WindowsProcess-17733085 | WindowProcess.HandleProcessCreated: Unable to parse AppSettings.SendDirectGenericEvents. Value='(null)'
INFO | 2018-05-21 18:49:10,432 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,432 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target OpenSpan.Scout.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: OpenSpan.Scout.x32.dll
INFO | 2018-05-21 18:49:10,432 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target OpenSpan.Scout.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: OpenSpan.Scout.x32.dll
INFO | 2018-05-21 18:49:10,432 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module OpenSpan.Scout.x32.dll
INFO | 2018-05-21 18:49:10,448 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,448 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shlwapi-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-shlwapi-l1-1-0.dll
INFO | 2018-05-21 18:49:10,448 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shlwapi-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-shlwapi-l1-1-0.dll
INFO | 2018-05-21 18:49:10,417 | 13 | 13 | 8744 | MTA | Project | | | Interrogation started.
INFO | 2018-05-21 18:49:10,464 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-shlwapi-l1-1-0.dll
INFO | 2018-05-21 18:49:10,464 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,495 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target iexplore.exe - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: iexplore.exe
INFO | 2018-05-21 18:49:10,495 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target iexplore.exe - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: iexplore.exe
INFO | 2018-05-21 18:49:10,495 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module iexplore.exe
INFO | 2018-05-21 18:49:10,510 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,510 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target normaliz.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: normaliz.DLL
INFO | 2018-05-21 18:49:10,510 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target normaliz.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: normaliz.DLL
INFO | 2018-05-21 18:49:10,510 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module normaliz.DLL
INFO | 2018-05-21 18:49:10,526 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,526 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.sharedmemory.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.sharedmemory.x32.dll
INFO | 2018-05-21 18:49:10,526 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.sharedmemory.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.sharedmemory.x32.dll
INFO | 2018-05-21 18:49:10,526 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.sharedmemory.x32.dll
INFO | 2018-05-21 18:49:10,542 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-core-synch-l1-2-0.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-core-synch-l1-2-0.DLL
INFO | 2018-05-21 18:49:10,542 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-core-synch-l1-2-0.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-core-synch-l1-2-0.DLL
INFO | 2018-05-21 18:49:10,542 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-core-synch-l1-2-0.DLL
INFO | 2018-05-21 18:49:10,542 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,557 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target KERNELBASE.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: KERNELBASE.dll
INFO | 2018-05-21 18:49:10,557 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target KERNELBASE.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: KERNELBASE.dll
INFO | 2018-05-21 18:49:10,557 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module KERNELBASE.dll
INFO | 2018-05-21 18:49:10,557 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,557 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-user32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-user32-l1-1-0.dll
INFO | 2018-05-21 18:49:10,573 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-user32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-user32-l1-1-0.dll
INFO | 2018-05-21 18:49:10,573 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-user32-l1-1-0.dll
INFO | 2018-05-21 18:49:10,573 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,573 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target ntdll.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: ntdll.dll
INFO | 2018-05-21 18:49:10,573 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target ntdll.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: ntdll.dll
INFO | 2018-05-21 18:49:10,588 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module ntdll.dll
INFO | 2018-05-21 18:49:10,588 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,588 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target kernel32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: kernel32.dll
INFO | 2018-05-21 18:49:10,588 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target kernel32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: kernel32.dll
INFO | 2018-05-21 18:49:10,604 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module kernel32.dll
INFO | 2018-05-21 18:49:10,604 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,604 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target ADVAPI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: ADVAPI32.dll
INFO | 2018-05-21 18:49:10,604 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target ADVAPI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: ADVAPI32.dll
INFO | 2018-05-21 18:49:10,604 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module ADVAPI32.dll
INFO | 2018-05-21 18:49:10,620 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,620 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target msvcrt.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: msvcrt.dll
INFO | 2018-05-21 18:49:10,620 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target msvcrt.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: msvcrt.dll
INFO | 2018-05-21 18:49:10,620 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module msvcrt.dll
INFO | 2018-05-21 18:49:10,635 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target sechost.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: sechost.dll
INFO | 2018-05-21 18:49:10,635 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target sechost.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: sechost.dll
INFO | 2018-05-21 18:49:10,635 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module sechost.dll
INFO | 2018-05-21 18:49:10,635 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,651 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target user32.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: user32.DLL
INFO | 2018-05-21 18:49:10,651 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target user32.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: user32.DLL
INFO | 2018-05-21 18:49:10,651 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module user32.DLL
INFO | 2018-05-21 18:49:10,651 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,651 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target RPCRT4.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: RPCRT4.dll
INFO | 2018-05-21 18:49:10,666 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target RPCRT4.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: RPCRT4.dll
INFO | 2018-05-21 18:49:10,666 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module RPCRT4.dll
INFO | 2018-05-21 18:49:10,666 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,666 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target SspiCli.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: SspiCli.dll
INFO | 2018-05-21 18:49:10,666 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target SspiCli.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: SspiCli.dll
INFO | 2018-05-21 18:49:10,682 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module SspiCli.dll
INFO | 2018-05-21 18:49:10,682 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,698 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target CRYPTBASE.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: CRYPTBASE.dll
INFO | 2018-05-21 18:49:10,698 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target CRYPTBASE.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: CRYPTBASE.dll
INFO | 2018-05-21 18:49:10,698 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module CRYPTBASE.dll
INFO | 2018-05-21 18:49:10,698 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,713 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.security.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.security.x32.dll
INFO | 2018-05-21 18:49:10,713 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.security.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.security.x32.dll
INFO | 2018-05-21 18:49:10,713 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.security.x32.dll
INFO | 2018-05-21 18:49:10,713 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,713 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-normaliz-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-normaliz-l1-1-0.dll
INFO | 2018-05-21 18:49:10,729 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-normaliz-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-normaliz-l1-1-0.dll
INFO | 2018-05-21 18:49:10,729 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-normaliz-l1-1-0.dll
INFO | 2018-05-21 18:49:10,729 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,729 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-advapi32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-advapi32-l1-1-0.dll
INFO | 2018-05-21 18:49:10,729 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-advapi32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-advapi32-l1-1-0.dll
INFO | 2018-05-21 18:49:10,744 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-advapi32-l1-1-0.dll
INFO | 2018-05-21 18:49:10,744 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,744 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-version-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-version-l1-1-0.dll
INFO | 2018-05-21 18:49:10,744 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-version-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-version-l1-1-0.dll
INFO | 2018-05-21 18:49:10,760 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-version-l1-1-0.dll
INFO | 2018-05-21 18:49:10,760 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,760 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target SHELL32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: SHELL32.dll
INFO | 2018-05-21 18:49:10,760 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target SHELL32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: SHELL32.dll
INFO | 2018-05-21 18:49:10,760 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module SHELL32.dll
INFO | 2018-05-21 18:49:10,776 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,776 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target version.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: version.DLL
INFO | 2018-05-21 18:49:10,776 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target version.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: version.DLL
INFO | 2018-05-21 18:49:10,776 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module version.DLL
INFO | 2018-05-21 18:49:10,791 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,791 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target USP10.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: USP10.dll
INFO | 2018-05-21 18:49:10,791 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target USP10.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: USP10.dll
INFO | 2018-05-21 18:49:10,791 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module USP10.dll
INFO | 2018-05-21 18:49:10,807 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target LPK.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: LPK.dll
INFO | 2018-05-21 18:49:10,807 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target LPK.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: LPK.dll
INFO | 2018-05-21 18:49:10,807 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module LPK.dll
INFO | 2018-05-21 18:49:10,807 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,822 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target GDI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: GDI32.dll
INFO | 2018-05-21 18:49:10,822 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target GDI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: GDI32.dll
INFO | 2018-05-21 18:49:10,822 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module GDI32.dll
INFO | 2018-05-21 18:49:10,822 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,822 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target MSCTF.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: MSCTF.dll
INFO | 2018-05-21 18:49:10,838 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target MSCTF.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: MSCTF.dll
INFO | 2018-05-21 18:49:10,838 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module MSCTF.dll
INFO | 2018-05-21 18:49:10,838 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,838 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target IMM32.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: IMM32.DLL
INFO | 2018-05-21 18:49:10,838 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target IMM32.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: IMM32.DLL
INFO | 2018-05-21 18:49:10,854 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module IMM32.DLL
INFO | 2018-05-21 18:49:10,854 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,854 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target PGPmapih.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: PGPmapih.dll
INFO | 2018-05-21 18:49:10,854 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target PGPmapih.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: PGPmapih.dll
INFO | 2018-05-21 18:49:10,854 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module PGPmapih.dll
INFO | 2018-05-21 18:49:10,869 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,869 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target dbghelp.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: dbghelp.dll
INFO | 2018-05-21 18:49:10,869 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target dbghelp.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: dbghelp.dll
INFO | 2018-05-21 18:49:10,869 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module dbghelp.dll
INFO | 2018-05-21 18:49:10,885 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target PSAPI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: PSAPI.DLL
INFO | 2018-05-21 18:49:10,885 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target PSAPI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: PSAPI.DLL
INFO | 2018-05-21 18:49:10,885 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module PSAPI.DLL
INFO | 2018-05-21 18:49:10,885 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,900 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.wer.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.wer.x32.dll
INFO | 2018-05-21 18:49:10,900 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.wer.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.wer.x32.dll
INFO | 2018-05-21 18:49:10,900 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.wer.x32.dll
INFO | 2018-05-21 18:49:10,916 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,916 | rThread | 50 | 8744 | STA | Adapters | ACMESearchSystem | ActiveXFactory-5805043 | Control is matched. Target: ole32.dll, ParentTarget: null
INFO | 2018-05-21 18:49:10,916 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target OLEAUT32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: OLEAUT32.dll
INFO | 2018-05-21 18:49:10,932 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target OLEAUT32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: OLEAUT32.dll
INFO | 2018-05-21 18:49:10,932 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module OLEAUT32.dll
INFO | 2018-05-21 18:49:10,932 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,932 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870988
INFO | 2018-05-21 18:49:10,947 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870988
INFO | 2018-05-21 18:49:10,947 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,947 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870990
INFO | 2018-05-21 18:49:10,947 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870990
INFO | 2018-05-21 18:49:10,963 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,963 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target OpenSpan.Utilities.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: OpenSpan.Utilities.x32.dll
INFO | 2018-05-21 18:49:10,963 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target OpenSpan.Utilities.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: OpenSpan.Utilities.x32.dll
INFO | 2018-05-21 18:49:10,964 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module OpenSpan.Utilities.x32.dll
INFO | 2018-05-21 18:49:10,964 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,964 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870994
INFO | 2018-05-21 18:49:10,964 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870994
INFO | 2018-05-21 18:49:10,996 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:10,996 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870996
INFO | 2018-05-21 18:49:10,996 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870996
INFO | 2018-05-21 18:49:11,043 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,058 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870998
INFO | 2018-05-21 18:49:11,058 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870998
INFO | 2018-05-21 18:49:11,058 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,058 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871000
INFO | 2018-05-21 18:49:11,058 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871000
INFO | 2018-05-21 18:49:11,074 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,074 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.activex.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.activex.x32.dll
INFO | 2018-05-21 18:49:11,074 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.activex.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.activex.x32.dll
INFO | 2018-05-21 18:49:11,074 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.activex.x32.dll
INFO | 2018-05-21 18:49:11,090 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,090 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.brokers.windows.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.brokers.windows.x32.dll
INFO | 2018-05-21 18:49:11,090 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.brokers.windows.x32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.brokers.windows.x32.dll
INFO | 2018-05-21 18:49:11,090 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.brokers.windows.x32.dll
INFO | 2018-05-21 18:49:11,105 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target iertutil.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: iertutil.dll
INFO | 2018-05-21 18:49:11,105 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target iertutil.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: iertutil.dll
INFO | 2018-05-21 18:49:11,105 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module iertutil.dll
INFO | 2018-05-21 18:49:11,105 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,121 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target shlwapi.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: shlwapi.DLL
INFO | 2018-05-21 18:49:11,121 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target shlwapi.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: shlwapi.DLL
INFO | 2018-05-21 18:49:11,121 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module shlwapi.DLL
INFO | 2018-05-21 18:49:11,121 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,136 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shell32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-shell32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,136 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shell32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-shell32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,136 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-shell32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,152 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,152 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target apphelp.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: apphelp.dll
INFO | 2018-05-21 18:49:11,168 | rThread | 50 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target apphelp.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: apphelp.dll
INFO | 2018-05-21 18:49:11,168 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module apphelp.dll
INFO | 2018-05-21 18:49:11,448 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_PROCESS_CREATED received
DEBUG | 2018-05-21 18:49:11,448 | rThread | 50 | 8744 | STA | UI Connectors | | | ExpressTranslatorService.EnsureTranslatorsLoaded() - ENTER
INFO | 2018-05-21 18:49:11,464 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Attaching process 6912 (C:\Program Files\Internet Explorer\IEXPLORE.EXE) to WindowsProcess object
INFO | 2018-05-21 18:49:11,464 | rThread | 49 | 8744 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Found internal SetState2
INFO | 2018-05-21 18:49:11,464 | rThread | 49 | 8744 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Calling base...
INFO | 2018-05-21 18:49:11,480 | rThread | 49 | 8744 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Base called
INFO | 2018-05-21 18:49:11,480 | rThread | 50 | 8744 | STA | Adapter Reparenting | ACMESearchSystem | | WindowsReparentingManager.ProcessCreated: Process (IEXPLORE.EXE) created [Reparent=False]
ERROR | 2018-05-21 18:49:11,480 | rThread | 50 | 8744 | STA | Windows Adapter | ACMESearchSystem | OpenSpan.Adapters.Windows.WindowsProcess-17733085 | WindowProcess.HandleProcessCreated: Unable to parse AppSettings.SendDirectGenericEvents. Value='(null)'
INFO | 2018-05-21 18:49:11,495 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,511 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target IEXPLORE.EXE - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: IEXPLORE.EXE
INFO | 2018-05-21 18:49:11,526 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target IEXPLORE.EXE - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: IEXPLORE.EXE
INFO | 2018-05-21 18:49:11,526 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module IEXPLORE.EXE
INFO | 2018-05-21 18:49:11,526 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,526 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target ADVAPI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: ADVAPI32.dll
INFO | 2018-05-21 18:49:11,542 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target ADVAPI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: ADVAPI32.dll
INFO | 2018-05-21 18:49:11,542 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module ADVAPI32.dll
INFO | 2018-05-21 18:49:11,542 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,542 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target ntdll.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: ntdll.dll
INFO | 2018-05-21 18:49:11,558 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target ntdll.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: ntdll.dll
INFO | 2018-05-21 18:49:11,558 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module ntdll.dll
INFO | 2018-05-21 18:49:11,558 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,558 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shlwapi-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-shlwapi-l1-1-0.dll
INFO | 2018-05-21 18:49:11,558 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shlwapi-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-shlwapi-l1-1-0.dll
INFO | 2018-05-21 18:49:11,573 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-shlwapi-l1-1-0.dll
INFO | 2018-05-21 18:49:11,573 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,589 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target kernel32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: kernel32.dll
INFO | 2018-05-21 18:49:11,589 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target kernel32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: kernel32.dll
INFO | 2018-05-21 18:49:11,589 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module kernel32.dll
INFO | 2018-05-21 18:49:11,589 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,604 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target KERNELBASE.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: KERNELBASE.dll
INFO | 2018-05-21 18:49:11,604 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target KERNELBASE.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: KERNELBASE.dll
INFO | 2018-05-21 18:49:11,604 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module KERNELBASE.dll
INFO | 2018-05-21 18:49:11,604 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,620 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target OpenSpan.Scout.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: OpenSpan.Scout.x64.dll
INFO | 2018-05-21 18:49:11,620 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target OpenSpan.Scout.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: OpenSpan.Scout.x64.dll
INFO | 2018-05-21 18:49:11,620 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module OpenSpan.Scout.x64.dll
INFO | 2018-05-21 18:49:11,620 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,636 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target msvcrt.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: msvcrt.dll
INFO | 2018-05-21 18:49:11,636 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target msvcrt.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: msvcrt.dll
INFO | 2018-05-21 18:49:11,636 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module msvcrt.dll
INFO | 2018-05-21 18:49:11,636 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,636 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-core-synch-l1-2-0.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-core-synch-l1-2-0.DLL
INFO | 2018-05-21 18:49:11,651 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-core-synch-l1-2-0.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-core-synch-l1-2-0.DLL
INFO | 2018-05-21 18:49:11,651 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-core-synch-l1-2-0.DLL
INFO | 2018-05-21 18:49:11,651 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,667 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target sechost.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: sechost.dll
INFO | 2018-05-21 18:49:11,667 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target sechost.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: sechost.dll
INFO | 2018-05-21 18:49:11,667 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module sechost.dll
INFO | 2018-05-21 18:49:11,667 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,682 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target RPCRT4.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: RPCRT4.dll
INFO | 2018-05-21 18:49:11,682 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target RPCRT4.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: RPCRT4.dll
INFO | 2018-05-21 18:49:11,682 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module RPCRT4.dll
INFO | 2018-05-21 18:49:11,682 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,698 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.security.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.security.x64.dll
INFO | 2018-05-21 18:49:11,698 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.security.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.security.x64.dll
INFO | 2018-05-21 18:49:11,698 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.security.x64.dll
INFO | 2018-05-21 18:49:11,698 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,714 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.sharedmemory.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.sharedmemory.x64.dll
INFO | 2018-05-21 18:49:11,714 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.sharedmemory.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.sharedmemory.x64.dll
INFO | 2018-05-21 18:49:11,714 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.sharedmemory.x64.dll
INFO | 2018-05-21 18:49:11,714 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,729 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-advapi32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-advapi32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,729 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-advapi32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-advapi32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,729 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-advapi32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,729 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,745 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shell32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-shell32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,745 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shell32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-shell32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,745 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-shell32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,745 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,760 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target PGPmapih.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: PGPmapih.dll
INFO | 2018-05-21 18:49:11,760 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target PGPmapih.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: PGPmapih.dll
INFO | 2018-05-21 18:49:11,760 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module PGPmapih.dll
INFO | 2018-05-21 18:49:11,760 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,776 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-version-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-version-l1-1-0.dll
INFO | 2018-05-21 18:49:11,776 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-version-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-version-l1-1-0.dll
INFO | 2018-05-21 18:49:11,776 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-version-l1-1-0.dll
INFO | 2018-05-21 18:49:11,776 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,792 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-user32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-user32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,792 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-user32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-user32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,792 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-user32-l1-1-0.dll
INFO | 2018-05-21 18:49:11,792 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,807 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-normaliz-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-normaliz-l1-1-0.dll
INFO | 2018-05-21 18:49:11,807 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-normaliz-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-normaliz-l1-1-0.dll
INFO | 2018-05-21 18:49:11,807 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-normaliz-l1-1-0.dll
INFO | 2018-05-21 18:49:11,807 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,823 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target normaliz.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: normaliz.DLL
INFO | 2018-05-21 18:49:11,823 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target normaliz.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: normaliz.DLL
INFO | 2018-05-21 18:49:11,823 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module normaliz.DLL
INFO | 2018-05-21 18:49:11,823 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,823 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target USP10.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: USP10.dll
INFO | 2018-05-21 18:49:11,838 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target USP10.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: USP10.dll
INFO | 2018-05-21 18:49:11,838 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module USP10.dll
INFO | 2018-05-21 18:49:11,838 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,838 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target USER32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: USER32.dll
INFO | 2018-05-21 18:49:11,854 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target USER32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: USER32.dll
INFO | 2018-05-21 18:49:11,854 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module USER32.dll
INFO | 2018-05-21 18:49:11,854 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,854 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target LPK.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: LPK.dll
INFO | 2018-05-21 18:49:11,854 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target LPK.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: LPK.dll
INFO | 2018-05-21 18:49:11,870 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module LPK.dll
INFO | 2018-05-21 18:49:11,870 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,870 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target GDI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: GDI32.dll
INFO | 2018-05-21 18:49:11,870 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target GDI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: GDI32.dll
INFO | 2018-05-21 18:49:11,885 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module GDI32.dll
INFO | 2018-05-21 18:49:11,885 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,885 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target MSCTF.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: MSCTF.dll
INFO | 2018-05-21 18:49:11,885 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target MSCTF.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: MSCTF.dll
INFO | 2018-05-21 18:49:11,885 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module MSCTF.dll
INFO | 2018-05-21 18:49:11,901 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,901 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target IMM32.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: IMM32.DLL
INFO | 2018-05-21 18:49:11,901 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target IMM32.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: IMM32.DLL
INFO | 2018-05-21 18:49:11,901 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module IMM32.DLL
INFO | 2018-05-21 18:49:11,916 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,916 | rThread | 49 | 8744 | STA | ClonedInstanceBroker | | | Serialized 'C:\Users\rajasekhar.uppuluri\Documents\Pega Robotics Studio\Projects\TrainingCertification\TrainingWebAdapter\ACMESearchSystem.os' in 0.00 seconds
INFO | 2018-05-21 18:49:11,932 | rThread | 49 | 8744 | STA | Cloned Instance Broker | | | Registering instance - Name: ActiveXFactory ContextId: WebAdapter-8D5BF31E9E19A8D\ActiveXFactory-8D5BF4A22C6BF47 Key: 11e86fa9-7d67-4e41-93d0-762a37245e27
INFO | 2018-05-21 18:49:11,932 | rThread | 49 | 8744 | STA | Keys | ACMESearchSystem | ActiveXFactory-28257748 | CreateClone - new clone has id: WebAdapter-8D5BF31E9E19A8D\ActiveXFactory-8D5BF4A22C6BF47
INFO | 2018-05-21 18:49:11,932 | rThread | 49 | 8744 | STA | Adapters | ACMESearchSystem | ActiveXFactory-5805043 | Control is matched. Target: ole32.dll, ParentTarget: null
INFO | 2018-05-21 18:49:11,948 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,948 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target OLEAUT32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: OLEAUT32.dll
INFO | 2018-05-21 18:49:11,948 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target OLEAUT32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: OLEAUT32.dll
INFO | 2018-05-21 18:49:11,948 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module OLEAUT32.dll
INFO | 2018-05-21 18:49:11,963 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,963 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870976
INFO | 2018-05-21 18:49:11,963 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870976
INFO | 2018-05-21 18:49:11,979 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870978
INFO | 2018-05-21 18:49:11,979 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870978
INFO | 2018-05-21 18:49:11,979 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:11,994 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target OpenSpan.Utilities.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: OpenSpan.Utilities.x64.dll
INFO | 2018-05-21 18:49:11,994 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target OpenSpan.Utilities.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: OpenSpan.Utilities.x64.dll
INFO | 2018-05-21 18:49:11,994 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module OpenSpan.Utilities.x64.dll
INFO | 2018-05-21 18:49:12,010 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,010 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870982
INFO | 2018-05-21 18:49:12,010 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870982
INFO | 2018-05-21 18:49:12,026 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870984
INFO | 2018-05-21 18:49:12,026 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870984
INFO | 2018-05-21 18:49:12,072 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,072 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870986
INFO | 2018-05-21 18:49:12,072 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870986
INFO | 2018-05-21 18:49:12,072 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536870988
INFO | 2018-05-21 18:49:12,088 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536870988
INFO | 2018-05-21 18:49:12,088 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,088 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.activex.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.activex.x64.dll
INFO | 2018-05-21 18:49:12,088 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.activex.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.activex.x64.dll
INFO | 2018-05-21 18:49:12,104 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.activex.x64.dll
INFO | 2018-05-21 18:49:12,104 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,104 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.brokers.windows.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.brokers.windows.x64.dll
INFO | 2018-05-21 18:49:12,104 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.brokers.windows.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.brokers.windows.x64.dll
INFO | 2018-05-21 18:49:12,119 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.brokers.windows.x64.dll
INFO | 2018-05-21 18:49:12,119 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,119 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target SHLWAPI.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: SHLWAPI.dll
INFO | 2018-05-21 18:49:12,119 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target SHLWAPI.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: SHLWAPI.dll
INFO | 2018-05-21 18:49:12,119 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module SHLWAPI.dll
INFO | 2018-05-21 18:49:12,135 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,135 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target dbghelp.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: dbghelp.dll
INFO | 2018-05-21 18:49:12,135 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target dbghelp.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: dbghelp.dll
INFO | 2018-05-21 18:49:12,150 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module dbghelp.dll
INFO | 2018-05-21 18:49:12,150 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,150 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target PSAPI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: PSAPI.DLL
INFO | 2018-05-21 18:49:12,150 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target PSAPI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: PSAPI.DLL
INFO | 2018-05-21 18:49:12,166 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module PSAPI.DLL
INFO | 2018-05-21 18:49:12,166 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,166 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871000
INFO | 2018-05-21 18:49:12,166 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871000
INFO | 2018-05-21 18:49:12,182 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871002
INFO | 2018-05-21 18:49:12,182 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871002
INFO | 2018-05-21 18:49:12,182 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,182 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.wer.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.wer.x64.dll
INFO | 2018-05-21 18:49:12,197 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.wer.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.wer.x64.dll
INFO | 2018-05-21 18:49:12,197 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.wer.x64.dll
INFO | 2018-05-21 18:49:12,197 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,197 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target shell32.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: shell32.DLL
INFO | 2018-05-21 18:49:12,213 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target shell32.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: shell32.DLL
INFO | 2018-05-21 18:49:12,213 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module shell32.DLL
INFO | 2018-05-21 18:49:12,213 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,213 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target version.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: version.DLL
INFO | 2018-05-21 18:49:12,213 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target version.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: version.DLL
INFO | 2018-05-21 18:49:12,228 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module version.DLL
INFO | 2018-05-21 18:49:12,228 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,228 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target iertutil.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: iertutil.dll
INFO | 2018-05-21 18:49:12,228 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target iertutil.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: iertutil.dll
INFO | 2018-05-21 18:49:12,244 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module iertutil.dll
INFO | 2018-05-21 18:49:12,244 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,244 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target CRYPTBASE.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: CRYPTBASE.DLL
INFO | 2018-05-21 18:49:12,244 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target CRYPTBASE.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: CRYPTBASE.DLL
INFO | 2018-05-21 18:49:12,260 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module CRYPTBASE.DLL
INFO | 2018-05-21 18:49:12,260 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,260 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871014
INFO | 2018-05-21 18:49:12,260 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871014
INFO | 2018-05-21 18:49:12,275 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,275 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871016
INFO | 2018-05-21 18:49:12,275 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871016
INFO | 2018-05-21 18:49:12,291 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871018
INFO | 2018-05-21 18:49:12,291 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871018
INFO | 2018-05-21 18:49:12,291 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,291 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871020
INFO | 2018-05-21 18:49:12,291 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871020
INFO | 2018-05-21 18:49:12,306 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,306 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871022
INFO | 2018-05-21 18:49:12,306 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871022
INFO | 2018-05-21 18:49:12,306 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871024
INFO | 2018-05-21 18:49:12,322 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871024
INFO | 2018-05-21 18:49:12,322 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,322 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871026
INFO | 2018-05-21 18:49:12,322 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871026
INFO | 2018-05-21 18:49:12,338 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,338 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target comctl32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: comctl32.dll
INFO | 2018-05-21 18:49:12,338 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target comctl32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: comctl32.dll
INFO | 2018-05-21 18:49:12,353 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module comctl32.dll
INFO | 2018-05-21 18:49:12,353 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,384 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target IEFRAME.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: IEFRAME.dll
INFO | 2018-05-21 18:49:12,400 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target IEFRAME.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: IEFRAME.dll
INFO | 2018-05-21 18:49:12,400 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module IEFRAME.dll
INFO | 2018-05-21 18:49:12,400 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,400 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871032
INFO | 2018-05-21 18:49:12,416 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871032
INFO | 2018-05-21 18:49:12,416 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,416 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871034
INFO | 2018-05-21 18:49:12,416 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871034
INFO | 2018-05-21 18:49:12,431 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target IEShims.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: IEShims.dll
INFO | 2018-05-21 18:49:12,431 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target IEShims.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: IEShims.dll
INFO | 2018-05-21 18:49:12,431 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module IEShims.dll
INFO | 2018-05-21 18:49:12,447 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,447 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target comdlg32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: comdlg32.dll
INFO | 2018-05-21 18:49:12,447 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target comdlg32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: comdlg32.dll
INFO | 2018-05-21 18:49:12,462 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module comdlg32.dll
INFO | 2018-05-21 18:49:12,462 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,462 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target uxtheme.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: uxtheme.dll
INFO | 2018-05-21 18:49:12,478 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target uxtheme.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: uxtheme.dll
INFO | 2018-05-21 18:49:12,478 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module uxtheme.dll
INFO | 2018-05-21 18:49:12,478 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,494 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target PGPhk.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: PGPhk.dll
INFO | 2018-05-21 18:49:12,494 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target PGPhk.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: PGPhk.dll
INFO | 2018-05-21 18:49:12,494 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module PGPhk.dll
INFO | 2018-05-21 18:49:12,494 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,509 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-ole32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-ole32-l1-1-0.dll
INFO | 2018-05-21 18:49:12,509 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-ole32-l1-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-ole32-l1-1-0.dll
INFO | 2018-05-21 18:49:12,509 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-ole32-l1-1-0.dll
INFO | 2018-05-21 18:49:12,525 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,525 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871046
INFO | 2018-05-21 18:49:12,540 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871046
INFO | 2018-05-21 18:49:12,540 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,540 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871048
INFO | 2018-05-21 18:49:12,540 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871048
INFO | 2018-05-21 18:49:12,556 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,556 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871050
INFO | 2018-05-21 18:49:12,556 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871050
INFO | 2018-05-21 18:49:12,572 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871052
INFO | 2018-05-21 18:49:12,572 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871052
INFO | 2018-05-21 18:49:12,572 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,572 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871054
INFO | 2018-05-21 18:49:12,572 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871054
INFO | 2018-05-21 18:49:12,587 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,587 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871056
INFO | 2018-05-21 18:49:12,587 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871056
INFO | 2018-05-21 18:49:12,603 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,603 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871058
INFO | 2018-05-21 18:49:12,603 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871058
INFO | 2018-05-21 18:49:12,618 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,634 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871060
INFO | 2018-05-21 18:49:12,634 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871060
INFO | 2018-05-21 18:49:12,634 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,634 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871062
INFO | 2018-05-21 18:49:12,650 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871062
INFO | 2018-05-21 18:49:12,650 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,665 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871064
INFO | 2018-05-21 18:49:12,665 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871064
INFO | 2018-05-21 18:49:12,665 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,665 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871066
INFO | 2018-05-21 18:49:12,681 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871066
INFO | 2018-05-21 18:49:12,681 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,681 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871068
INFO | 2018-05-21 18:49:12,681 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871068
INFO | 2018-05-21 18:49:12,682 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,682 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target profapi.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: profapi.dll
INFO | 2018-05-21 18:49:12,682 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target profapi.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: profapi.dll
INFO | 2018-05-21 18:49:12,682 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module profapi.dll
INFO | 2018-05-21 18:49:12,714 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,714 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target USERENV.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: USERENV.dll
INFO | 2018-05-21 18:49:12,714 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target USERENV.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: USERENV.dll
INFO | 2018-05-21 18:49:12,714 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module USERENV.dll
INFO | 2018-05-21 18:49:12,730 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,730 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871074
INFO | 2018-05-21 18:49:12,730 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871074
INFO | 2018-05-21 18:49:12,745 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target WININET.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: WININET.dll
INFO | 2018-05-21 18:49:12,745 | rThread | 49 | 8744 | STA | Adapters | ACMESearchSystem | WinInetFactory-25754381 | Control is matched. Target: WININET.dll, ParentTarget: null
INFO | 2018-05-21 18:49:12,761 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,761 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871078
INFO | 2018-05-21 18:49:12,761 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871078
INFO | 2018-05-21 18:49:12,761 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871080
INFO | 2018-05-21 18:49:12,776 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871080
INFO | 2018-05-21 18:49:12,776 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,776 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target openspan.wininet.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: openspan.wininet.x64.dll
INFO | 2018-05-21 18:49:12,792 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target openspan.wininet.x64.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: openspan.wininet.x64.dll
INFO | 2018-05-21 18:49:12,792 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module openspan.wininet.x64.dll
INFO | 2018-05-21 18:49:12,792 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,808 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target urlmon.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: urlmon.dll
INFO | 2018-05-21 18:49:12,808 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target urlmon.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: urlmon.dll
INFO | 2018-05-21 18:49:12,808 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module urlmon.dll
INFO | 2018-05-21 18:49:12,808 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,823 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target dwmapi.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: dwmapi.dll
INFO | 2018-05-21 18:49:12,823 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target dwmapi.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: dwmapi.dll
INFO | 2018-05-21 18:49:12,823 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module dwmapi.dll
DEBUG | 2018-05-21 18:49:12,823 | rThread | 49 | 8744 | STA | UI Connectors | | | ExpressTranslatorService.EnsureTranslatorsLoaded() - ENTER
INFO | 2018-05-21 18:49:12,839 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Window Created - HWND:00010B4E
INFO | 2018-05-21 18:49:12,839 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,839 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target sqmapi.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: sqmapi.dll
INFO | 2018-05-21 18:49:12,854 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target sqmapi.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: sqmapi.dll
INFO | 2018-05-21 18:49:12,854 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module sqmapi.dll
INFO | 2018-05-21 18:49:12,854 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,854 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target Secur32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: Secur32.dll
INFO | 2018-05-21 18:49:12,870 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target Secur32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: Secur32.dll
INFO | 2018-05-21 18:49:12,870 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module Secur32.dll
INFO | 2018-05-21 18:49:12,870 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,870 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target SSPICLI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: SSPICLI.DLL
INFO | 2018-05-21 18:49:12,886 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target SSPICLI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: SSPICLI.DLL
INFO | 2018-05-21 18:49:12,886 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module SSPICLI.DLL
INFO | 2018-05-21 18:49:12,886 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,901 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-advapi32-l2-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-advapi32-l2-1-0.dll
INFO | 2018-05-21 18:49:12,901 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-advapi32-l2-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-advapi32-l2-1-0.dll
INFO | 2018-05-21 18:49:12,901 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-advapi32-l2-1-0.dll
INFO | 2018-05-21 18:49:12,917 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,917 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target NSI.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: NSI.dll
INFO | 2018-05-21 18:49:12,917 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target NSI.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: NSI.dll
INFO | 2018-05-21 18:49:12,917 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module NSI.dll
INFO | 2018-05-21 18:49:12,932 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,932 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target WS2_32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: WS2_32.dll
INFO | 2018-05-21 18:49:12,932 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target WS2_32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: WS2_32.dll
INFO | 2018-05-21 18:49:12,948 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module WS2_32.dll
INFO | 2018-05-21 18:49:12,948 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,948 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target webio.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: webio.dll
INFO | 2018-05-21 18:49:12,948 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target webio.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: webio.dll
INFO | 2018-05-21 18:49:12,964 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module webio.dll
INFO | 2018-05-21 18:49:12,964 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,979 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target winhttp.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: winhttp.dll
INFO | 2018-05-21 18:49:12,979 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target winhttp.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: winhttp.dll
INFO | 2018-05-21 18:49:12,979 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module winhttp.dll
INFO | 2018-05-21 18:49:12,995 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:12,995 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target mswsock.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: mswsock.dll
INFO | 2018-05-21 18:49:12,995 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target mswsock.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: mswsock.dll
INFO | 2018-05-21 18:49:13,010 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module mswsock.dll
INFO | 2018-05-21 18:49:13,010 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,010 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shlwapi-l2-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: api-ms-win-downlevel-shlwapi-l2-1-0.dll
INFO | 2018-05-21 18:49:13,010 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target api-ms-win-downlevel-shlwapi-l2-1-0.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: api-ms-win-downlevel-shlwapi-l2-1-0.dll
INFO | 2018-05-21 18:49:13,182 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module api-ms-win-downlevel-shlwapi-l2-1-0.dll
INFO | 2018-05-21 18:49:13,198 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,213 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target wship6.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: wship6.dll
INFO | 2018-05-21 18:49:13,213 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target wship6.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: wship6.dll
INFO | 2018-05-21 18:49:13,213 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module wship6.dll
INFO | 2018-05-21 18:49:13,229 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,229 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target WINNSI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: WINNSI.DLL
INFO | 2018-05-21 18:49:13,229 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target WINNSI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: WINNSI.DLL
INFO | 2018-05-21 18:49:13,229 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module WINNSI.DLL
INFO | 2018-05-21 18:49:13,244 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,244 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target IPHLPAPI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: IPHLPAPI.DLL
INFO | 2018-05-21 18:49:13,244 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target IPHLPAPI.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: IPHLPAPI.DLL
INFO | 2018-05-21 18:49:13,244 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module IPHLPAPI.DLL
INFO | 2018-05-21 18:49:13,260 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,260 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target wshtcpip.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: wshtcpip.dll
INFO | 2018-05-21 18:49:13,260 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target wshtcpip.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: wshtcpip.dll
INFO | 2018-05-21 18:49:13,260 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module wshtcpip.dll
INFO | 2018-05-21 18:49:13,276 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,276 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target DNSAPI.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: DNSAPI.dll
INFO | 2018-05-21 18:49:13,276 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target DNSAPI.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: DNSAPI.dll
INFO | 2018-05-21 18:49:13,276 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module DNSAPI.dll
INFO | 2018-05-21 18:49:13,291 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,291 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target NamespaceToEvents.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: NamespaceToEvents.dll
INFO | 2018-05-21 18:49:13,291 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target NamespaceToEvents.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: NamespaceToEvents.dll
INFO | 2018-05-21 18:49:13,291 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module NamespaceToEvents.dll
DEBUG | 2018-05-21 18:49:13,307 | rThread | 49 | 8744 | STA | UI Connectors | | | ExpressTranslatorService.EnsureTranslatorsLoaded() - ENTER
INFO | 2018-05-21 18:49:13,307 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Window Created - HWND:00010B50
INFO | 2018-05-21 18:49:13,307 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,307 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target dhcpcsvc.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: dhcpcsvc.DLL
INFO | 2018-05-21 18:49:13,322 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target dhcpcsvc.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: dhcpcsvc.DLL
INFO | 2018-05-21 18:49:13,322 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module dhcpcsvc.DLL
INFO | 2018-05-21 18:49:13,322 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,322 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target dhcpcsvc6.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: dhcpcsvc6.DLL
INFO | 2018-05-21 18:49:13,338 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target dhcpcsvc6.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: dhcpcsvc6.DLL
INFO | 2018-05-21 18:49:13,338 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module dhcpcsvc6.DLL
DEBUG | 2018-05-21 18:49:13,338 | rThread | 49 | 8744 | STA | UI Connectors | | | ExpressTranslatorService.EnsureTranslatorsLoaded() - ENTER
INFO | 2018-05-21 18:49:13,338 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Window Created - HWND:00010B52
INFO | 2018-05-21 18:49:13,354 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,354 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target CRYPTSP.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: CRYPTSP.dll
INFO | 2018-05-21 18:49:13,354 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target CRYPTSP.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: CRYPTSP.dll
INFO | 2018-05-21 18:49:13,369 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module CRYPTSP.dll
INFO | 2018-05-21 18:49:13,369 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,369 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target rasadhlp.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: rasadhlp.dll
INFO | 2018-05-21 18:49:13,385 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target rasadhlp.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: rasadhlp.dll
INFO | 2018-05-21 18:49:13,385 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module rasadhlp.dll
INFO | 2018-05-21 18:49:13,385 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,400 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target rsaenh.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: rsaenh.dll
INFO | 2018-05-21 18:49:13,400 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target rsaenh.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: rsaenh.dll
INFO | 2018-05-21 18:49:13,400 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module rsaenh.dll
INFO | 2018-05-21 18:49:13,400 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,416 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target RpcRtRemote.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: RpcRtRemote.dll
INFO | 2018-05-21 18:49:13,416 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target RpcRtRemote.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: RpcRtRemote.dll
INFO | 2018-05-21 18:49:13,416 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module RpcRtRemote.dll
INFO | 2018-05-21 18:49:13,416 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,432 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target CLBCatQ.DLL - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: CLBCatQ.DLL
INFO | 2018-05-21 18:49:13,432 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target CLBCatQ.DLL - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: CLBCatQ.DLL
INFO | 2018-05-21 18:49:13,432 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module CLBCatQ.DLL
INFO | 2018-05-21 18:49:13,432 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,447 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871144
INFO | 2018-05-21 18:49:13,447 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871144
INFO | 2018-05-21 18:49:13,447 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,447 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Windows module list already contains module with handle 536871146
INFO | 2018-05-21 18:49:13,447 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Could not get WindowsModule for module with handle 536871146
INFO | 2018-05-21 18:49:13,463 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,463 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target ieproxy.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: ieproxy.dll
INFO | 2018-05-21 18:49:13,463 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target ieproxy.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: ieproxy.dll
INFO | 2018-05-21 18:49:13,463 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module ieproxy.dll
INFO | 2018-05-21 18:49:13,494 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,494 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target netutils.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: netutils.dll
INFO | 2018-05-21 18:49:13,510 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target netutils.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: netutils.dll
INFO | 2018-05-21 18:49:13,510 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module netutils.dll
INFO | 2018-05-21 18:49:13,510 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,510 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target srvcli.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: srvcli.dll
INFO | 2018-05-21 18:49:13,525 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target srvcli.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: srvcli.dll
INFO | 2018-05-21 18:49:13,525 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module srvcli.dll
INFO | 2018-05-21 18:49:13,525 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,525 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target wkscli.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: wkscli.dll
INFO | 2018-05-21 18:49:13,541 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target wkscli.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: wkscli.dll
INFO | 2018-05-21 18:49:13,541 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module wkscli.dll
INFO | 2018-05-21 18:49:13,541 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,541 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target NETAPI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: NETAPI32.dll
INFO | 2018-05-21 18:49:13,556 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target NETAPI32.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: NETAPI32.dll
INFO | 2018-05-21 18:49:13,556 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module NETAPI32.dll
INFO | 2018-05-21 18:49:13,588 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,588 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target apphelp.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: apphelp.dll
INFO | 2018-05-21 18:49:13,603 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target apphelp.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: apphelp.dll
INFO | 2018-05-21 18:49:13,603 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module apphelp.dll
INFO | 2018-05-21 18:49:13,744 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | WM_OS_LIBRARY_LOADED received
INFO | 2018-05-21 18:49:13,759 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | ActiveXFactory-5805043 | ModuleNameMatchRule failed for target fwpuclnt.dll - Mode: Simple, Value: Simple|True|(User Culture)|ole32.dll, Target Value: fwpuclnt.dll
INFO | 2018-05-21 18:49:13,775 | rThread | 49 | 8744 | STA | Matching | ACMESearchSystem | WinInetFactory-25754381 | ModuleNameMatchRule failed for target fwpuclnt.dll - Mode: Simple, Value: Simple|True|(User Culture)|wininet.dll, Target Value: fwpuclnt.dll
INFO | 2018-05-21 18:49:13,775 | rThread | 49 | 8744 | STA | Windows Adapter | ACMESearchSystem | | Valid factory not found for module fwpuclnt.dll
INFO | 2018-05-21 18:49:24,461 | 51 | 51 | 8744 | MTA | | | | Process IEXPLORE.EXE with id 6912 has been destroyed.
INFO | 2018-05-21 18:49:24,476 | 51 | 51 | 8744 | MTA | Windows Adapter | | | Process IEXPLORE.EXE with id 6912 has been destroyed.
INFO | 2018-05-21 18:49:24,476 | 51 | 51 | 8744 | MTA | Windows Adapter | ACMESearchSystem | | WindowsProcess.DestroyWindow (HWND:00010B4E)
INFO | 2018-05-21 18:49:24,476 | 51 | 51 | 8744 | MTA | Windows Adapter | ACMESearchSystem | | WindowsProcess.DestroyWindow (HWND:00010B52)
INFO | 2018-05-21 18:49:24,476 | 51 | 51 | 8744 | MTA | Windows Adapter | ACMESearchSystem | | WindowsProcess.DestroyWindow (HWND:00010B50)
INFO | 2018-05-21 18:49:24,492 | 51 | 51 | 8744 | MTA | Adapters | ACMESearchSystem | ActiveXFactory-28257748 | ControlBase.Detach(destroyControl:True) - Control is detached
INFO | 2018-05-21 18:49:24,476 | 53 | 53 | 8744 | MTA | | | | Process iexplore.exe with id 9732 has been destroyed.
INFO | 2018-05-21 18:49:24,492 | 53 | 53 | 8744 | MTA | Windows Adapter | | | Process iexplore.exe with id 9732 has been destroyed.
INFO | 2018-05-21 18:49:24,507 | 53 | 53 | 8744 | MTA | Windows Adapter | | | All processes in adapter have been removed.
INFO | 2018-05-21 18:49:24,507 | 53 | 53 | 8744 | MTA | Web Adapter | ACMESearchSystem | | Stopping adapter
INFO | 2018-05-21 18:49:24,507 | 53 | 53 | 8744 | MTA | Adapters | ACMESearchSystem | ActiveXFactory-5805043 | ControlBase.Detach(destroyControl:True) - Control is detached
INFO | 2018-05-21 18:49:24,492 | 57 | 57 | 8744 | MTA | Cloned Instance Broker | | | Unregistering instance. ContextID: WebAdapter-8D5BF31E9E19A8D\ActiveXFactory-8D5BF4A22C6BF47
INFO | 2018-05-21 18:49:24,492 | 51 | 51 | 8744 | MTA | Adapters | ACMESearchSystem | WinInetFactory-25754381 | ControlBase.Detach(destroyControl:True) - Control is detached
INFO | 2018-05-21 18:49:24,570 | 53 | 53 | 8744 | MTA | Project | | | Interrogation stopped.
INFO | 2018-05-21 18:49:24,585 | 53 | 53 | 8744 | MTA | Web Adapter | ACMESearchSystem | | Adapter stopped
Please Help in Resolving the issue. Thanks in Advance.............
Issue is resolved by running the "Pega Robotics Studio" as "Run As Administrator"
