Time delay to see the dasahboard in portal
Dashboard takes a lot of time to load. Also the grid shows up empty sometimes and needs 2 to 3 times of refresh to populate the values.
Hi ,
Try to get the performance profiler reading from from designer studio-system-performance while refreshing the dashboard. It could be because you db interaction is taking some time or because of some complicated logic while fetching the data . You can use defer load as well.
The grid contains some unexposed properties. Could this cause any delay ?
Generally to read the unexposed properties from the blob column, it might cause performance delay depends on the number of unexposed properties that are being used in the grid. You can try to expose those properties and check the difference in performance.
If the unexposed columns are getting fetched from the DB then of course it will cause a performance issue .
