Accenture
CN
Last activity: 30 Mar 2020 23:28 EDT
Is there any bug in my Solution?
I try to click an button to download a pdf file for user. but I don't want use action[Open URL in window]. So I use JS to call my Activty for this.like below
But a bug is happened. when I first click button is work well. but Second click this button [Action not allowed as it is outside current transaction] error is happened.
So I add some JS code for this. (// add code start and // add code end)Now it is work well. Is there any bug in my Solution?
function downloadFile(activityName, className, applicationName){
var suURL = SafeURL_createFromURL(pega.u.d.url);
suURL.put("pyActivity", activityName);
suURL.put("pyClassName", className);
suURL.put('ApplicationName', applicationName);
// add code start
suURL.put("pzFromFrame","");
// add code start
// add code end
var formEle = document.createElement('form');
formEle.id = "download_file";
formEle.method = "POST";
formEle.action = suURL.toURL();
if(pega.env.ua.webkit)formEle.target = "";
document.body.appendChild(formEle);
formEle.submit();
document.body.removeChild(formEle);
// add code start
var url = document.forms[0].action;
var formURL = SafeURL_createFromURL(url);
formURL.put("pzFromFrame","");;
document.forms[0].action= formURL.toURL();
// add code end
could you give me some suggestion for this. Thank you very very much.
