Slowness in Portal load.
We are facing slowness when our portal loads. When traced we found that "Following Cases" section triggers a SQL ( D_pxfavorites thru RD pyFollowedCases in section Data-Portal • pyPortalNav under harness Data-Portal • pyCaseManager7).
The SQL formed for our portal is
SELECT "PC0".PYID AS "pyID", "PC0".PYLABEL AS "pyLabel", "PC0".PZINSKEY AS "pzInsKey" FROM PRPC_71SDS_pool.pccs_work "PC0"
INNER JOIN PRPC_71SDS_pool.pc_index_workparty "Party"
ON
(( ( ("PC0".PZINSKEY = "Party".PXINSINDEXEDKEY) ) AND ("PC0".PXOBJCLASS LIKE 'MellonFinCorp-GCM-CSWork%') AND ("Party".PXOBJCLASS = 'Index-WorkPartyUri') ) ) WHERE ( ("Party".PXPARTYROLE = 'Follower') AND ("Party".PYPARTYIDENTIFIER = 'XBBJ293') ) AND ("Party".PXINDEXPURPOSE = 'PartyURI')
Though this returns 0 results it takes 10-15 mins to execute.
- Count of PRPC_71SDS_pool.pccs_work is 1598483
 - Count of PRPC_71SDS_pool.pc_index_workparty is 16563939
Is this because of the count we have DB performance issue? I am sure there are applications with much more records and do they face this issue?? Since these are all OOB and help or suggestion will be appreciated.
