Nat West Group
Last activity: 27 Dec 2018 9:07 EST
SLA for ExecuteProgramRun flow in marketing not triggering the expecting log message
I have a requirement to log message if the executeProgramRun flow does not complete with in a specified time . I am not sure if SLA given in the flow is picked up and I am unable to trace the requestor thread. Also the log message is not seen anywhere in the log files. Need your expert assistance.
In order to provide assistance some more information is needed. Can you please explain further what you mean by 'I am not sure if SLA given in the flow is picked up'? Have you customized the 'executeProgramRun' flow? Also, please indicate what version of Pega Marketing and Pega you have installed.
Some more information about the use case requiring logging the message would be helpful too. Logging a message doesn't seem like the most effective mechanism for communicating this information.
Amy
Nat West Group
The problem statement is to trigger an alert when a campaign is not completing with in a stipulated time . So the design which I could think of was to customise the ExecuteProgramRun flow and include an SLA in the design which I am not able trace or confirm if its being executed. that is what I am trying to convey in 'I am not sure if SLA given in the flow is picked up'? . Please let me know if you have a better approach to achieve this requirement.
Adaps
Could you please find the below link:
https://community1.pega.com/community/product-support/question/how-slas-work-pega
Nat West Group
HI,
I am finding it difficult to trace the requestor session as it throws some local host error. Any idea how to identify if the SLA is invoked?
Nat West Group
Can anyone help me with this query please? I tried tracing the SLA but am not able to . Is there any way to establish the functionality?
Could you explain in a bit more detail how you will use this log data. Is the intention to monitor campaign performance by reviewing the logs for these messages? Or is there a plan for some action to be taken when the log entry is recorded? Having an understanding of the goal could help us provide more assistance.
Starting in Pega Marketing 7.31 there are some extension points available in the ExecuteProgramRun flow. If possible it would be advisable to use these instead of overtaking the flow itself.
What version of Pega Marketing are you using?
Amy
Nat West Group
We have a requirement to trigger an incident /notification if the campaign does not completed with in the prescribed time. There is a Tivoli system which will listen to PegaRules.log file for configured alerts and raise an incident depending on the alert.
For now the design that I have thought of is to write a log-Message in the SLA activity, which would in turn be read by the external system.
Version of Pega marketing -7.31
Please let me know if any of the available extension points would help complete this requirement.
Nat West Group
I had raised an SR parallely and found that this issue exists only with ExecuteProgramRun flow .
Hi @DivyaV19 ,
Do let us know the SR number so that we can connect the post to the SR and the troubleshooting is concentrated at a single place.
Thanks!
Hi @DivyaV19,
I found the SR you opened and linked this PSC post to it and notified the Engineer working it.
Let us know the resolution when you reach one!
Thanks!
Nat West Group
Thanks Marissa. Will do , once we arrive at the resolution.
Hi @DivyaV19!
I see that your Support Request has been resolved and that you were asked to check all of the node logs to see the log messages.
Did that resolve this for you?
Nat West Group
Yes Marissa, i am in the process of verifying the solution provided. will keep this thread posted . We have a dev rebuild scheduled in the first week of Jan , will confirm the SLA issue after the rebuild
Sounds good @DivyaV19! Looking forward to hearing how it goes!
