Declare Triggers through Data Flow
PRPC Version 7.2.1
In a data flow, i am writing a record to a data set. (Mapped to a data base table).
As far as i have tested, Declare trigger is not getting fired. This makes sense as its not a typical obj-save.
Is this expected behavior? I don't want the declare trigger to be fired in this scenario.
Hi Raju_Botu,
Thanks for posting on PSC.
Local Change:
In "Declare Trigger" rule for property COL1 with the configuration as TRIGGER WHEN AN INSTANCE IS “Commited Save” option in the drop-down.
Hope it helps. Kindly notify for larger Pega audience by marking this post as answered.
Asif
