Amerprise Financial
Last activity: 18 Jul 2017 10:36 EDT
Declare Trigger Activty
We have a declare trigger activity defined at the work object class to commit few changes to one physical data base table with pyStatuswork & one other Specific tracking properties. At the trigger activity we have the necessary property set for the new class (mapped to physical DB table) with Obj-Save adding to the deferred list and expecting the Deferred save to commit the changes with the Assignment/Work object commit.
Problem Statement: Work Object status was changing from Open* to Resolved* and since we had a Declare trigger event on status & other specific property we have two events logged one from Open Status & other from Resolved Status. Our trigger activity is firing with two Obj-Save one with Open Status timestamp of 20150618T165945.245 GMT and 20150618T165945.927 GMT of Resolve timestamp and expecting when final commit happens the Obj-Save with the deferred list should execute in the order of queue (First come first out) execution. But in our case the Resolved one is executing first.
Attempted Solution: We tried using explicit Commit since Trigger activity doesn't allow Obj-Save with write now and it worked correctly. As this method forcing work object changes to commit and no deferred list.
As per Pega Help documentation Commit/Obj-Save with write now shouldn't be used with Declare triggers.
Please share your inputs if you have come across such issues.
***Updated by moderator: Lochan to close post***
Aren't declare-triggers defined on an entire class rather than a specific property ? /Eric
