HCL
Last activity: 4 Sep 2023 13:01 EDT
ResumeFlow from SLA is not triggering the rest of the flow and only performs the flow action alone
I have a requirement where i have a WB with a defined SLA of 1 hour. Post 1 hour the flow must be resumed i.e the case should move on to a utility where a API retry will be attempted if still exception persists then case needs to be reassigned back to same WB(using connector shape).
My SLA is triggering and Resume Flow performs the flow action(flowactionautosubmit), however the utility and reassignment of case to the WB is not happening. i tried with AdvanceFlow option present in SLA actions as well. No luck
Any help on how to tackle this would be appreciated! TIA
