Runtime shutting down after registering the bot
Runtime version: 2033
Pega version: 7.3.1
Robot Manager: 4.1
Runtime log
Pega version: 7.3.1
Robot Manager: 4.1
Runtime log
WARN | 2019-09-11 18:13:25,718 | 1 | 1 | 2332 | STA | Manifest | | | Configuration manifest file 'C:\Users\ID\AppData\Roaming\OpenSpan\DesktopAnalyticsConfig.xml' does not exist.
INFO | 2019-09-11 18:13:25,733 | 1 | 1 | 2332 | STA | Runtime Application | | | Runtime external shutdown support was activated via the command line
INFO | 2019-09-11 18:13:25,749 | 1 | 1 | 2332 | STA | Robotics | | | RoboticsApiHelper.RegisterRobot - Robot registration started. Robot Name: 'HOSTVDAASW1010553', Workgroup: 'RoboProcess', Authentication Mode: 'Basic'.
INFO | 2019-09-11 18:13:26,249 | 1 | 1 | 2332 | STA | Robotics | | | RoboticsApiHelper.RegisterRobot - Robot registration succeeded.
ERROR | 2019-09-11 18:13:26,327 | 1 | 1 | 2332 | STA | DiagnosticExceptionHandler | | | Unhandled Exception: No MediaTypeFormatter is available to read an object of type 'RobotContent' from content with media type 'text/html'.
ERROR | 2019-09-11 18:13:26,358 | 1 | 1 | 2332 | STA | Exception | | | No MediaTypeFormatter is available to read an object of type 'RobotContent' from content with media type 'text/html'., Verbose Message: General Information
Diagnostic Info:
Diagnostic.MachineName: VDAASW1010553
Diagnostic.FullName: OpenSpan, Version=8.0.0.0, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e
Diagnostic.AppDomainName: OpenSpan.Runtime.exe
Diagnostic.WindowsIdentity: US\AE08058
Diagnostic.ApplicationName: OpenSpan.Runtime
Exception Information
1) Exception Information
Exception Type: System.InvalidOperationException
Message: "No MediaTypeFormatter is available to read an object of type 'RobotContent' from content with media type 'text/html'."
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: System.Threading.Tasks.Task`1[T] ReadAsAsync[T](System.Net.Http.HttpContent, System.Type, System.Collections.Generic.IEnumerable`1[System.Net.Http.Formatting.MediaTypeFormatter], System.Net.Http.Formatting.IFormatterLogger)
HelpLink: NULL
Source: "System.Net.Http.Formatting"
HResult: -2146233079
StackTrace Information
Pega log
Robot registration started....
Registering the robot for the first time
Fetching the Dynamic System Setting to validate the precedence...
Payload workgroup takes precedence than decision table...
Validating payload workgroup...
Registering robot to workgroup: RoboProcess
Response status from Pega as success
Commonconfig.xml
<Servers>
<Server name="RobotManager" baseURL="https://host name: port/prweb" enabled="true" proxyAddress="" RPA="true" workgroup="RoboProcess" robotName="Host" authenticationType="Basic"/>
<Server name="Config" baseURL="https://omc.openspan.com/" enabled="false" proxyAddress=""/>
<Server name="Intelligence" baseURL="https://WFIID-wfi.openspan.com" enabled="false" proxyAddress=""/>
<Server name="IdP" baseURL="https://MyAuthServer.com/Endpoint" enabled="false" proxyAddress=""/>
</Servers>
Runtimeconfig.xml
<LocalApiService enabled="true" SSL="true" port="9443" allowedOrigins="*" JWTSecurity="false" PegaServerURL="https://MyPegaServer.com/RobotMgr"/>
<!-- PackageServer baseUrl: Address of the Package Server API endpoint. -->
<PackageServer baseUrl="https://host name: port/prweb/api/v1"/>
