Pega Robot Runtime client shutting down abruptly V19.1.66
Hi ,
I'm facing an issue with Pega Robotic Runtime client were it shutdowns abruptly, below is the runtime log that has been captured.
Only one application is launched via the runtime client [Except launching of app, no other operation is performed by the BOT] , after sometime the client shuts down thus closing the application launched via client.
Any pointers on how to troubleshoot the issue ?
Varun
Runtime Log Details :
Hi ,
Varun
Info | 11:34:01.593 AM | 12 | STA | | | | WindowsProcess.WndProc( 526534, 8001, 10926, 0 )
Verbose | 11:34:01.593 AM | 12 | STA | Windows Messages | Siebel | | Received message - HWND:001806E8, msg: WM_LBUTTONUP
Info | 11:34:01.862 AM | 12 | STA | | | | WindowsProcess.WndProc( 526534, 8001, 10928, 0 )
Verbose | 11:34:01.862 AM | 12 | STA | Windows Messages | Siebel | | Received message - HWND:001806E8, msg: WM_KEYDOWN
Info | 11:34:02.277 AM | 12 | STA | | | | WindowsProcess.WndProc( 526534, 8001, 10930, 0 )
Verbose | 11:34:02.277 AM | 12 | STA | Windows Messages | Siebel | | Received message - HWND:001806E8, msg: WM_KEYDOWN
Info | 11:34:02.277 AM | 12 | STA | | | | WindowsProcess.WndProc( 526534, 8006, 10932, 0 )
Verbose | 11:34:02.277 AM | 12 | STA | Windows Messages | Siebel | | Processed message - HWND:001806E8, msg: WM_COPY
Verbose | 11:34:02.355 AM | 6 | MTA | Events | | | HLE.ProcessMonitor Timer Elapsed 11:34:02.3555176 6
Error | 11:34:02.362 AM | 5 | MTA | DiagnosticExceptionHandler | | | Unhandled Exception: Object reference not set to an instance of an object.
Error | 11:34:02.377 AM | 5 | MTA | Exception | | | Object reference not set to an instance of an object., Verbose Message: General Information
Diagnostic Info:
Diagnostic.MachineName: SGR12345
Diagnostic.FullName: OpenSpan, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e
Diagnostic.AppDomainName: OpenSpan.Runtime.exe
Diagnostic.WindowsIdentity: Tst\123456
Diagnostic.ApplicationName: OpenSpan.Runtime
Exception Information
1) Exception Information
Exception Type: System.NullReferenceException
Message: "Object reference not set to an instance of an object."
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: Void PopulateEventDataArgs(OpenSpan.Server.Events.EventDataArgs, OpenSpan.Events.HighLevelEvents.FocusInfo, System.String)
HelpLink: NULL
Source: "OpenSpan.Events"
HResult: -2147467261
StackTrace Information
at OpenSpan.Events.HighLevelEvents.HighLevelEventService.PopulateEventDataArgs(EventDataArgs args, FocusInfo focusInfo, String rawEventSignature)
at OpenSpan.Events.HighLevelEvents.HighLevelEventService.BuildCCPEvent(String name, DateTime timestamp, Int32 processId, String type)
at OpenSpan.Events.HighLevelEvents.HighLevelEventService.<>c__DisplayClass184_0.<mHookManager_KeyDown>b__0()
at OpenSpan.Events.HighLevelEvents.SerialTaskQueue.<>c__DisplayClass9_0.<QueueUserWorkItem>b__0()
at OpenSpan.Events.HighLevelEvents.SerialTaskQueue.<>c__DisplayClass9_0.<QueueUserWorkItem>b__1(Object _)
at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
Verbose | 11:34:02.377 AM | 5 | MTA | | | | Firing UnhandledExceptionOccurred event.
Info | 11:34:02.377 AM | 5 | MTA | Events | | | EventName=FatalError EventType=Operational TimeStamp=27/07/2021 1:34:02 AM
ContextIdentity=00000000-0000-0000-0000-000000000000
Data:
ExceptionType=NullReferenceException, MachineName=NAWWIP505153, ExceptionMessage=Object reference not set to an instance of an object., ExceptionStackTrace= at OpenSpan.Events.HighLevelEvents.HighLevelEventService.PopulateEventDataArgs(EventDataArgs args, FocusInfo focusInfo, String rawEventSignature)
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback(), PackageName=EPARDA_BCOS_Main, PackageId=Project-8D6DACED5AFAE33, PackageVersionMajor=1, PackageVersionMinor=64, PackageVersionBuild=-1, PackageVersionRevision=-1, ConfigurationName=, RuntimeVersionMajor=19, RuntimeVersionMinor=1, RuntimeVersionBuild=66, RuntimeVersionRevision=0
Verbose | 11:34:02.377 AM | 5 | MTA | Runtime Application | | | RuntimeLoader.Shutdown() Entered
Info | 11:34:02.377 AM | 5 | MTA | Runtime Application | | | RuntimeLoader.Shutdown() Invoking onto MainForm thread.
Verbose | 11:34:02.377 AM | 1 | STA | Runtime Application | | | WndProc message = 0000C1D2
Verbose | 11:34:02.377 AM | 1 | STA | Runtime Application | | | RuntimeLoader.Shutdown() Entered
Verbose | 11:34:02.377 AM | 1 | STA | Manifest | | | There is no configuration redirect for Shutdown section.
Info | 11:34:02.377 AM | 1 | STA | Events | | | EventName=RuntimeShutdown EventType=Operational TimeStamp=27/07/2021 1:34:02 AM
Data:
UserInitiated=False
Verbose | 11:34:02.377 AM | 1 | STA | Events | | | HLE.ProcessMonitor Timer Stopped
Verbose | 11:34:02.393 AM | 1 | STA | Listener | | | Resolver: assembly 'Interop.SensEvents' is loaded successfully
Verbose | 11:34:02.408 AM | 1 | STA | Runtime | | | Stop all projects
