Robotics runtime 8.0.2021 unable to shut itself down on Windows 10
When testing the new runtime 8.0.2021 on Windows 10, I found it unable to shutdown itself using the following method. After everything is done, the runtime still stays in memory.
The same solution worked with the old version 8.0.2007. The log entry 'Error reading Shutdown setting. Unexpected Setting: '' ' was found for both versions but the old version was able to shutdown. Any suggestion is appreciated.
