Sinarmas MSIG Life
ID
Last activity: 30 Jul 2018 6:49 EDT
Routing Workbasket
I am using routing workbasket on assignment properties. I set "IT" workbasket on assignment properties and on my operator account.
But, when I create case, my section not appear. Only "THANK YOU FOR YOUR INPUT" is show.
How to make my section directly appear when I create a case?
Thanks for all response.
note : I am using Pega 7.2.1
Hi Maulana,
If you need a section after case creation by default, add another assignment shape just before the current assignment where you are using routing.
With current design every time you would create a case, assignments would get routed and you would not see the intended section.
Ujjwal
Hi Maulana,
It seems that you have not configured any section with Flow Action coming out of Assignment and hence you have the reported behaviour.
Right click on connector coming out of assignment to see the properties, configure a flow action(existing/createNew) and then configure section there.
Ujjwal
Sinarmas MSIG Life
ID
Thanks for your answer.
I already configured section with Flow Action on connector of my assignment.
Everything is normal when routing is empty, but when I set my workbasket on routing, then my section not appear.
Maulana
Ok, it is because assignment is not in your work-list anymore and has been transferred.
Check audit logs to find the details regarding the same.
Ujjwal
EPAM Systems, Inc.
ES
Sinarmas MSIG Life
ID
Hi AsifHasan,
Case not available on my worklist, all case routed to my workbasket list.
I only need my first section which routed to my workbasket is directly appear when I create a case. Because other workbasket didn't permit to create a new case. Can I?
Virtusa
Hi Maulana,
This is a completely different question how did u map Category Created such columns in above Img. Canu Plese Let me know.
How it is down.
Jayan
Sinarmas MSIG Life
ID
Hi JayandraK,
U can add some property in report definition which is sources for "My Work" data page (Cretaed from .pxCreateDateTime property)
Ncs Pte Ltd
SG
Open that workbasket and check operator lists and Login with that operator and open your work item
Else Create an operator ID and pass same workbasket for operator workbasket and try with that operator
Sinarmas MSIG Life
ID
Hi RohitS3082,
Ya, I am Login with operator which have same workbasket. But I didn't get my first section, only "THANK YOU FOR YOUR INPUT" is appear.
Hi Maulana,
Ujjwal
