Reg HFix-9120 to support Oracle DB Upgrade from 11g to 12c version for Pega 6.3 SP1.
We received a HFix-9120 to support our Oracle DB Upgrade from 11g to 12c version for Pega 6.3 SP1. They have mentioned that the hotfix needs to be imported after the upgrade to 12c since the HFix-9120 is for PRPC v6.3 SP1 support for Oracle 12c (Pega Platform 6.3 SP1). The question is, if we do the DB upgrade without the hotfix, will it cause any issues during the application start up OR the application startup doesn't really depend on what is there in the hotfix and it is ok to import it after that?
Hello Sivaguru!
You must apply HFix-9120 prior to upgrading Oracle from a previous version (for example, Oracle 11g) to Oracle 12c; otherwise, the PRPC engine will not start.
Thank you,
Pawan
