PE 8.7 Installs but does not function correctly even after reinstall
Hi, I have a new laptop on which I have installed PE8.7. The install did not go as documented and I had to run the install more than once to get it to complete. I have tried deleting and starting again but with the same outcome.
Starting the application I got an error that required me to update a DSS for pega-uiengine!constellationsvcURL
I can start and open the application and have created my own 'React' application in the instance but I keep getting problems (blue ring) when I try to follow the UI elements in App Studio (configure view etc).
I dont know if the problem is with the initial install not working as expected or if its a problem with the React Application.
Any help gratefully received
