Modifying the Existing Design: Moving the Initialization Stage to the Primary Stage
Our application is currently running on Pega Infinity 24.2.1. Since the auto-save feature does not work during the Initialization Stage, we are considering moving the Initialization Stage to the Primary Stage.
Can we keep only basic configurations in the new Initialization Stage? Would this change be feasible? Do you foresee any issues with existing cases? If we proceed with this change, what precautions should we take? If anyone faced the similar issue, could you please share your thoughts.
@srinit Yes, you can move the Initialization Stage logic to the Primary Stage, especially if you need auto-save to work during early data entry. Keep the new Initialization Stage minimal just system-level setup like setting pyLabel, routing, or setting default values. This change is generally safe but test it well with existing cases. For in-flight cases, make sure they don’t break due to stage mismatch; consider locking old cases or using a when rule to skip the new Initialization Stage. Backup your app before the change and test it in lower environments first. Others have done this successfully, so it’s a common workaround.
