Low Compliance Score post 7.2.1 upgrade
We upgraded a customer application from 6.3 to 7.2.1, On checking the compliance score we are seeing a value of 0 out 100!
And as per platform upgrade expectations, for the Pega 7 platform the acceptable score would be > 90%; hence we have a feeling that we are in troubled waters.
Any areas of concern/reason of why we are getting such a low compliance score? What are the areas we should look at primarily?
How feasible would it be to increase it to graeter than 80% at least?
P.S - 75% of our rules are compliant
Hi Bidyun
Did you run 'revalidate and save' after the upgrade? If not, can you please run it once?
You can run 'revalidate and save' that comes with Pega OOTB from "Designer Studio > System > Release > Upgrade > Validate > Revalidate and Save." you need to run it by selecting rule type and ruleset name. If you want to run 'revalidate and save' in bulk, you can use Pega7 upgrade accelerator pack (formerly ECS Upgrade Utilities), it can be downloaded from https://community.pega.com/marketplace/components/pega-7-upgrade-accelerator-pack
Please check the guardrail score after running it and let us know.
Sandeep
