infosys
infosys
infosys
Posted: Nov 10, 2023
Last activity: Nov 10, 2023
Last activity: 10 Nov 2023 9:21 EST
Getting below error while trying to trigger an email from an external assignment in pega. Test connectivity is working finefine
Unable to open an instance using the given inputs: pxObjClass = "Data-Party-Person", pyWorkPartyUri = "xyz @ gmail .com"
[ Proprietary data (email address) removed by moderator]
***Edited by Moderator Marije to change Type from Discussion to Question, type from Pega Academy to Product***
@Nazeer Pasha there are restrictions when using DWA
Directed Web Access in configuring assignments for external users
This error typically occurs when Pega is unable to find the required data based on the provided inputs. In the context of Directed Web Access (DWA), it could be due to incorrect configuration or missing data.
Please ensure that the 'Data-Party-Person' instance and 'pyWorkPartyUri' are correctly configured and exist in your system. The 'pyWorkPartyUri' should match the operator ID for the external user.
If the issue persists, you may need to debug further by tracing the email listener or checking the logs for more detailed error messages.
Please go through the below previous PSC posts:
Configuring Directed Web Access
Can't open work object using email
Error : "Unable to open assignee's Data-Admin-Operator-ID record Administrato
User should be able to launch assignment from an email
DWA URL opening but asking logins to login Y?
