Can't open work object using email
I'm not able to open case using Email and it should load on perform harness. below code used to open the work object . can any one help me to sort this out.
<a href="https://MyURL/PRAuth/SSO1?pyActivity=Data-Portal.ShowDesktop&isSnapStart=true&pyShowFullPortal=true&applicationName=EAccess&Action=OpenAssignment&InsHandle={%
appendString(pega_rules_utilities.encodeURLParameter(tools.getProperty(".pzInsKey").getStringValue()));
%}">Please Click</a>
@AnuradhaW
For opening the case in perform mode, you need to pass Assign- key of that assignment.
If you are passing work object pzInsKey as a value to InsHandle parameter than system will open the assignment in review mode only.
In mail link activity, by using pzInsKey of the work object you could have your logic to get Assign- pzInsKey. And then initialize Assign- pzInsKey value to InsHandle parameter.
Please find screenshot for reference.
